Rattle on acceleration
Old Oct 16, 2007 | 04:09 AM
Jam's Avatar
Jam
Stage II
Default Rattle on acceleration
Hi all
Wonder if you can help me. I have a well stored1987 Heritage that has only 14000 miles on it. As it is one of only 2 Harleys (82 Sturgis)I have ever owned I dont take to much notice of noises etc.
However after taking a mate for ride on the back he asked me why my bike makes a rattle when I change into the next gear when accelerating. I began to think about it...... DAM
Any idea's? As I reach about 3500 rpm and the power fades a little I change gears but just before I reach this the top end (I think) rattles. From memory it has always done it but I never took notice before. Now everytime I wind on the gas and get to the higher end of rpm I hear this rattle.
Thoughts would be appreciated.
S&S B Series (Never had a drama)
After market Taper Turbo's
K&N
are my only mods on the old girl. I run high octane fuel and doubt this to be detonation or any of that other stuff I now am nowreading about.
I hate my friend!!!!! hahaha
Thanks Jam[X(]
Old Oct 16, 2007 | 09:10 AM
Dr.Hess's Avatar
Dr.Hess
Default RE: Rattle on acceleration
Without listening to your noise, it's pretty hard to tell what it is.
However, you should be able to spin that thing way beyond 3500 RPM. It should pull strong up to wherever the redline is, like 5K, 5.5K or so and the power should certainly not drop off at 3500. It almost sounds like you have a lifter or two either colapsing at 3500, which would expain the noise and the power drop off. The early Evo motors, while (in my opinion) the best motor HD ever made, are said to have weak lifters, which were upgraded a few years later. Get some new HD lifters and some adjustable EZ install push rods and I bet you'll be good to go.
Old Oct 16, 2007 | 09:13 AM
800XC SP's Avatar
800XC SP
I had a rattle on my my well preserved (10,000 miles on it when I bought it 2 summers ago) 1993 Heritage I coudn't figure out. Well after a season I did. It's the brake peddle arm. Only happens on the higher rpm range, if I stick my boot under it and lift it a bit, no rattle.
Just a thought.......
Old Oct 16, 2007 | 09:49 AM
fmbeach's Avatar
fmbeach
Same thought as 800XC. I have chased down many rattles on my '97 Heritage. All tins and covers (especially) those on the left side are suspect, shifter arms,headlight nacelle and windsheild brackets tend to rattle over time.Compensator as well can rattle at higher RPM. My .02 cents.
bturner484
Dec 23, 2020 04:18 PM
Joe-Cool
Aug 10, 2014 09:34 PM
paceFLHTC
Aug 21, 2012 08:20 PM
thelawnmowerman
Jun 25, 2012 03:52 PM
cappy
EVO
Jun 27, 2008 05:33 AM
