89 FXR oil puking
Old Oct 25, 2009 | 08:23 AM
miacycles's Avatar
miacycles
try your local indy, the may have one layin around, or would set one aside when they have one come in. You don't need a whole one, a half will do!!
Old Oct 25, 2009 | 03:08 PM
guspup's Avatar
guspup
6th Gear
I will make some calls on Monday. ˝ of a push rod will fit in an envelope & go in a mailbox if need be. Even if you had someone cut it in ˝ just to mail it. Of all the help I have seen on this problem, the link below looks to be the true fix! This sumping problem is what brought me to HDForums.com in the first place. Thanks for the tip!!!
http://www.bigboyzcycles.com/showthread.php?t=87
Old Oct 25, 2009 | 07:50 PM
Dr.Hess's Avatar
Dr.Hess
I'm pretty sure I have a half-a-pushrod tube in my scrap pile of "round stuff for future projects" under the lathe. I can look if you want. Keep in mind that it has about 60-70K miles on it, so if you want to start out with a new one, that may not be your best choice.
Old Oct 26, 2009 | 11:18 AM
guspup's Avatar
guspup
6th Gear
Default Thank you Dr Hess
The first call I made led me to a push rod. Thank you for your help!
Old Oct 26, 2009 | 11:58 AM
fxstcguy98's Avatar
fxstcguy98
I bought two check *****, (they are dirt cheap), then JBwelded it a straight piece of one of those thick plastic coat hanger. Worked great.
Glen St. Mary
EVO
Nov 11, 2014 04:07 PM
9192daveyc
Engine Mechanical Topics
Apr 22, 2014 02:52 PM
shovel boy
Shovelhead
Nov 10, 2010 10:20 PM
Frowg
Oil Archive (no new posts)
Mar 22, 2007 01:23 PM
pastor2wes
Apr 8, 2006 11:43 AM
