Transmission shifting
Old Jan 14, 2008 | 01:40 AM
gigiflip's Avatar
gigiflip
Default Transmission shifting
OK guys. 1998 FXSTC with about 20K on the speedo. I've noticed that when I put her into first, I get a definite "clunk". When I shift through all gears, I get a definite "clunk". When I am hard on the gas, I canjust feel the tranny shafts spinning through the shifter lever (IE, I can just makeout a slight grind through the lever). The oil has not changed colour. Last change there was no filings. I adjusted the clutch back to manual specs, but it is all still there. I know the evo tranny is a clunker (my brother in laws FXR definitely clunked), but does this sound normal. BTW, the tranny has no noises when running hard or soft and holds a gear without any problems.
Cheers, Bill.
Old Jan 14, 2008 | 01:55 AM
pistole's Avatar
pistole
Default RE: Transmission shifting
- mine "clunks" too , when getting into first.
- aren't they all like that ?
Old Jan 14, 2008 | 02:54 AM
pajoe's Avatar
pajoe
We bought a new '95 Buell Blast for the wife a couple years ago, and it has the same clunk as our '90 Ultra. Our '90 Ultra has about 96,000 miles on it and of those about 32,000 since we have it. The only real problem we had with the transmission was the 50 cent shifter return spring broke, and nicked up a few gears. Once in a while when the Ultra hot it will miss a gear, then I don't get any clunk... They say using HD synthetic oil makes it better but I can't say I noticed any really big improvement using synthetic.
Old Jan 14, 2008 | 05:35 AM
Lumpy63's Avatar
Lumpy63
A few things come to mind:
1.) is the primary fluid too full? Too full can cause excess drag on the trans and effect shifting and clunking.
2.) Is the clutch properly adjusted? (Both clutch basket AND lever)
3.) I switched to Redline Heavy Shock,Synthetic Gear lube, 80w-90, and it made a world of difference.
I bought it through Summit Racing at about $9.00 a qt. The trans clunks less, is quieter and shifts smoother.
Old Jan 14, 2008 | 01:47 PM
miacycles's Avatar
miacycles
Try changing fluid to Red Line or Royal Purple something like a 75 or more as the first number and a 140 for the last number ( each brandhas a little different numbers available) it will slow don the gears and quite the "klunck" a lot.
Old Jan 18, 2008 | 07:33 PM
89 FXRS's Avatar
89 FXRS
It's a Harley. So concerning the clunk, well, It's a Harley.
I have owned a Pan , then a Shovel, and now my Evo. They all clunked in first.
Now for the joke of the day:
If Harley made a airplane, would you fly in it?
Old Jan 18, 2008 | 08:25 PM
pistole's Avatar
pistole
ORIGINAL: 89 FXRS
- seeing as how harleys are so
simple in terms of engineering, yeah ...
- but .....
Old Jan 18, 2008 | 09:42 PM
meveratt's Avatar
meveratt
My 98 Dyna clunks into first too. Even after changing fluids, checking clutch and primary chain tension. So -- I assume its normal. In fact, I kinda like it! Lets me know I'm ready to roll!
Mike
Old Jan 19, 2008 | 08:39 AM
89 FXRS's Avatar
89 FXRS
ORIGINAL: pistole
ORIGINAL: 89 FXRS
- but .....
Simple yes, Harley always has been. Although do you want to hear or feel a CLUNK in your airplane. Makes you think, right.
Old Jan 19, 2008 | 02:13 PM
Fat Henry's Avatar
Fat Henry
[blockquote]quote:
ORIGINAL: pistole
[blockquote]quote:
ORIGINAL: 89 FXRS
If Harley made a airplane, would you fly in it?[/blockquote]
- but .....
[/blockquote]
Only if its EVO Powered
