pushrods
Old Feb 7, 2008 | 06:08 PM
saihager's Avatar
saihager
Default pushrods
Does anybody have instructions for rev tech pushrod time-savers; '96 Heritage 80CI?
Old Feb 8, 2008 | 02:39 AM
pajoe's Avatar
pajoe
Default RE: pushrods
I am not sure if these instructions are what you want,
I tried doing a scan and running the OCR, sorry if there are errors
CUSTOM CHROME INSTRUCTIONS
High Performance by Custom Chrome
RevTech Adjustable Aluminum Pushrods-CCI #59-221
RevTech Adjustable Chromemoly Pushrods-CCI #59-227
For Big Twin Evolution Models
Copyright 1996. Custom Chrome, Inc.
YOU HAVE PURCHASED THE FINEST REMOVABLE PUSHRODS AVAILABLE TODAY. THESE
PUSHRODS MAY BE INSTALLED WITHOUT REMOVING THE CAM COVER OR ROCKER BOXES.
1. Disconnect negative battery cable and tape end.
2. Remove front and rear spark pluqs.
3. Raise rear wheel off the ground with a jack or suitable lift, Place the motorcycle in high
gear.
4. Remove all pushrod cover clips. Rotate motor usinq rear wheel until the front cylinder
pushrods are at their lowest position (TDC compression stroke). Remove pushrods with
bolt cutters being careful not to scratch painted surface. Remove all used pushod cover
O-rings.
5. Shorten two RevTech pushrods completely. Placing RevTech pushrods in covers with
new O-rings in place, lnsert pushrod in roccker box and lifter base.
6. While holding adjuster wilh 5/16 wrench extend pushrod by rotating pushrod body until
there is no play or side shake in pushrod assembly.
7. Extend the length of the pushrod 4 full turns using the open end of a 1/2 inch wrench.
Note the number of the flat facing you and rotate the top of pushrod up until that
number appears the fourth time, Tighten lock nut securely.
**** WARNING ****
You must wait until the front lifters bleed down before turning the motor over. When the
front pushrod can be turned freely, they are bled down.
8, Repeat steps 4, 5, 6 and 7 for the rear cylinder, Here again wait until the pushrod can be
turned freely before turning the motor over.
9. Re-check all lock nuts, reinstall pushrod clips, ground cable and spark plugs, Place bike
in neutral and remove jack or lift.
10. Start bike and check for oil leaks around the pushrod tubes.
1600 Jacqueline Court, Morgan Hill, CA 95037-5598
[IMG][/IMG]
[IMG]local://upfiles/1956/CEB90F9B468C40C59D49AB0A17E6DB33.jpg[/IMG]
There is good information in the tech article section at Big Boys head porting
Big Boys Head Porting
Old Feb 8, 2008 | 07:44 PM
sqdealgeorge's Avatar
sqdealgeorge
Right on My customs plus my 93 FLHS have these push rods
98glider
Ironhead
Nov 18, 2012 05:32 PM
sugarplum247
Ironhead
20
Sep 20, 2012 07:52 AM
ironheadred
Ironhead
May 9, 2011 06:17 PM
Weed's Ironscoot
Ironhead
Jul 12, 2010 08:37 PM
rigevo
EVO
Sep 1, 2009 06:03 AM
