Kickstarter with Dynatek ignition?
Old Dec 23, 2012 | 06:53 PM
tommyc's Avatar
tommyc
Stage I
Originally Posted by Rob85WG
I made a cable similar to the one described by Jtrapass here:
https://www.hdforums.com/forum/evo-c...ima-ign-2.html
I had to connect the cable and power on the ignition before starting the Curvemaker program. Otherwise the ignition was not found by the PC.
When you program the ignition the switches will no longer function. Make sure you set all of the parameters you need including single/dual fire, rev limit, and timing curve. If it screws up the performance, go to the diagnostics tab and click the button that reads "Use Switches" to set it back to normal.
goodluck
Hi bud, I hope you can help.
I got a 93" shovel with dyna 2000i. I'm programming the "break points" section now in curvemaker, how many degrees of timing advance is good to add and at what rpm's should I add it? Whats the max amount of timing degrees to add?
Should I add the same amount for WOT and part throttle?
Thanks.
Old Dec 24, 2012 | 12:05 AM
Rob85WG's Avatar
Rob85WG
Most people pick one of the curves that come with the Curvemaker software. There are 4 traditional curves available if you click "Load Curve" on the timing tab. Curve 1 is the most aggressive and has 35 degrees of advance.
It may be faster to use the dip switches first to choose a curve and then load the same curve number using the software.
Old Feb 10, 2013 | 10:37 PM
Rob85WG's Avatar
Rob85WG
Default Dyna2000i, Ultima ignition programming cable
Programming cable described here:
Old Jul 6, 2013 | 02:43 PM
brudseymour's Avatar
brudseymour
Stage III
I'm trying to find somewhere to get a dyna 2000i reprogrammed to zero dead revs is there anyone who can do this
Old Jul 6, 2013 | 03:36 PM
Rob85WG's Avatar
Rob85WG
If you want your own cable for $40 plus shipping go here: https://sites.google.com/site/vrusb2000i/
It is pretty easy to do.
Old Jul 10, 2013 | 10:07 AM
brudseymour
Stage III
is there anywhere I can send a dyna 2000i to get reprogrammed to zero dead revs....
Old Jul 11, 2013 | 07:05 PM
Rob85WG's Avatar
Rob85WG
I can do it for you but you'll have to buy a programming cable from me. That's $40 plus shipping. See the link that I posted above for details and my email.
Old Jun 8, 2015 | 09:02 AM
EvoSpringer's Avatar
EvoSpringer
I know this is a 2 year old thread but I was wondering if the guys that installed their Dynatek iggy and reprogrammed it for their kickstarter if it works good kicking? Im getting ready to install a Dyna 2000P on my 92 Softail Springer
Old Jun 8, 2015 | 05:30 PM
glidein wide's Avatar
glidein wide
Try a new thread for your question or send one of them a pm. It actually started in 2008, they all may not be watching. Good luck, twisted, mine kicks ok for stock ignition....
Old Jun 8, 2015 | 09:51 PM
Rob85WG's Avatar
Rob85WG
The shovehead guys more often have kickers and a lot of them use the Dyna2000i for its simplicity and ability to kick start. A guy we call Chopprs sells a lot of them with good results. I would post on a shovel forum for first hand testimony.
I kickstart my evo with a Dyna2000i.
