Coldblooded FXR
Old Feb 25, 2008 | 08:51 PM
kraig205's Avatar
kraig205
6th Gear
Default Coldblooded FXR
My 93 EVO is so hard to start. It has new Gel Cell battery, will turn over great and once it starts its great.Also a Dyna 2000 ignition. I am going to put in some new NGK plugs and hope they help. I don't think I am flooding it. Any
idea's.
Old Feb 25, 2008 | 08:58 PM
MJ's Avatar
MJ
Default RE: Coldblooded FXR
Not much info there to go on. choke/enrichner? turning over or turning over slow? Little more detail would help.
Old Feb 27, 2008 | 05:26 AM
brad75raiders's Avatar
brad75raiders
Have you checked your timing latley?? or what carb/comp pistons/heads/ignition are you running?
Old Feb 27, 2008 | 08:43 AM
sqdealgeorge's Avatar
sqdealgeorge
Check the enrichener(CV carb) Sometimes when you pull it out it won't stay there There is a place where you can tighten it Is the accelerator pump working (CV carb) Are the plugs getting wet? Dyna 2000 is a great ignition system
Old Feb 27, 2008 | 01:29 PM
Sharknose's Avatar
Sharknose
I used to have a '90 FXR. My cold start procedure was:
1. Turn on the gas
2. Open and close the throttle ONCE
3. Open the enrichener.
4. Hit "Start"
It would fire right up.
Old Feb 27, 2008 | 01:59 PM
badherb's Avatar
badherb
My 97 evo has ahard time starting when it's"brrrrrr" cold outside.
1. two twists of throttle
2. pull out enricher
3. hold throttle half open
4. crank until it starts to putt
5. once it is puttinglet go of the throttle while still cranking
somedays it takes two or three trys but she always starts and this works even if it is -10 degrees outside.
Old Feb 28, 2008 | 07:49 PM
kraig205's Avatar
kraig205
6th Gear
Thanks guy's I am going to give the those things a try over the weekend.Will let you know how it works out and will try to get a picture on here, just havingtrouble with the100kb limit.
Old Feb 28, 2008 | 09:25 PM
BlackAngus's Avatar
BlackAngus
Every Harley I have ever owned was cold blooded.
Old Mar 13, 2008 | 01:04 AM
NMDave's Avatar
NMDave
I think every engine is cold blooded in cold areas. Personally i don't own cold blooded motorcycles but i have always lived in the southwest.The original poster never mentioned what type of carb is on his motorcycle. That may make a difference on how you remedy hard starts. The Amal carbs on english bikes had ticklers that provided quick easy starts, i wonder why they don't employ them on today's American V-Twins.
David
Clay West
Shovelhead
Apr 16, 2018 08:10 AM
Ston
Shovelhead
Jul 7, 2017 10:02 PM
davp22
EVO
Aug 31, 2015 09:17 PM
Schulte94
Mar 6, 2014 10:41 PM
fast19971
Exhaust System Topics
Jul 16, 2009 05:40 PM
