blown headgasket
Old May 7, 2008 | 08:06 AM
miacycles's Avatar
miacycles
Default RE: blown headgasket
All threaded surfaces should be cleaned and either lubricated or loctited before assembly, that way your torque settings will be consistent.
Ethanol is ethyl alcohol or grain alcohol. In you burn straight alcohol (usually methanol which is a petroleum based alcohol) you need to richen your mixture by about 40%. Additionally you need to make compression ratio, timing, and float changes among other things. Failure to do these things can and will cause problems. When you introduce 10% ethanol into a motor that is already running lean you have a recipe for potential problems. Remember these motors were designed years age before ethanol was introduced or needed. That's why we have some of the problems we have now. Just my two cents worth.
Old May 18, 2008 | 11:38 PM
Slowride262's Avatar
Slowride262
When mine blew at 16,000 and when I got to it the right side bolts were loose and pushed the gasket out on that side.
That kind of sucked because it was just good and broke in and have to but new rings, rehone it new base gasketin because of 2 loose bolts.
Make sure you use your tap and die set and clean the threads before you button the thing back up.
Sandhog
EVO
Jul 26, 2017 10:08 PM
t-sport
Exhaust System Topics
Jan 2, 2014 04:38 AM
95 Ultra
EVO
Nov 12, 2012 10:00 PM
riderboy1961
Mar 17, 2008 08:50 PM
danmail3
Mar 17, 2006 06:22 PM
