no brake lights
Old May 10, 2008 | 10:37 PM
jammer1's Avatar
jammer1
Default RE: no brake lights
yes it dual filament two contacts on the bulb.I am thinking maybe ita grounding problem will have a look tommorrow.Thanks for all the help
Old May 11, 2008 | 12:07 AM
89 FXRS's Avatar
89 FXRS
If you have 12v when you place the tester at the brake light bulb socket,I do not think it is a grounding problem. I would have to guess the problem is at the socket and your connection with the bulb.
Old May 11, 2008 | 01:32 AM
megawatt's Avatar
megawatt
Your problem has to be the socket contact for the brake light not touching the bulb contact if the bulbs you tried are good. Everything you have described eliminates the ground connection and the 12v. supply to the socket so it has to be the bulb is not contacting the socket contact.
Beaneater912
Electrical/Lighting/Alarm
Sep 30, 2014 06:33 AM
jckazz333
Oct 29, 2011 11:08 AM
coach127
Dec 5, 2007 06:26 AM
95Heritage
May 27, 2007 09:46 AM
davidw221
Jul 5, 2006 12:27 AM
