Tire Pressure?
Old May 19, 2008 | 10:00 AM
tpgun10's Avatar
tpgun10
Default Tire Pressure?
I'm riding on pretty new HD white-wall Dunlops-D402 Touring Tires on my 88 Electra Glide Sport (FLHS).
Tires say tubeless.
Tire PSI say's 40 PSI.
Question-Run em at 40PSI or something different in front, something different in back-or same in both?
How often should they be checked really...Also do the cheap tire gauges really work well/accurate for checking?
Any good generaltire "tips".
Thx.
[IMG]local://upfiles/61418/149C3B5C52DD40E8BFD2BA7A10461BDD.jpg[/IMG]
Old May 19, 2008 | 10:07 AM
Fat Henry's Avatar
Fat Henry
Default RE: Tire Pressure?
Recommend a good gauge. I can only answer for what I know. (98 Fatboy)
36 psi F&R solo 40 PSI two up. Check it often.
Old May 19, 2008 | 10:27 AM
tpgun10's Avatar
tpgun10
OK-I see riding solo vs. two-up changes PSI recommendations...What is the REAL diff. in riding at ex: 36 vs. 40 PSI. Handling? Tire wear? safety?
Mine are 40PSI front and rear?
Thx.
Old May 19, 2008 | 06:43 PM
Fat Henry's Avatar
Fat Henry
At 40 psi you actually have less tire patch when solo. Tire patch is that area of the tire that is sitting on the road keeping you glued to it. Imagine a Basket ball with you sitting on it with 7psi The flat area on the ground is more than if the ball had 14 psi. On the other hand if you have too little air then the tire will begin to cup in the middle and you will have less area because now the tire is more like a rim with the out side edges only on the ground. The difference between solo and two up is the difference of the weight of two people vs one person. Check the tire pressure when cold because if you are riding around you will heat up the tires increasing the pressure. It is an optimization of too little pressure or too much depending on the tire temp. I hope this helps. So it effects all three of your choices.
Old May 19, 2008 | 06:59 PM
t150vej's Avatar
t150vej
I ride a Tour Glide (not so much weight difference at one might think) and I have the best luck with 36 front - 40 rear regardless of the load. And that's per the book. I get 13 - 14,000 on a rear and last front I pulled off had 36, 000 and plenty of tread left.(got tired of looking at it and never had 2 new skins on the bike at the same timesince I bought it)
Check them regularly, especially when the weather changes. Don't deflate if you've ridden more than 2 miles and they check high.
The biggest thing is longevity. Running a tire low for as little as 200 miles will cause it to start dipping out (especially D402) and when that happens, it'll keep on dipping regardless of the pressures you run.
18Slim
2018+ Softail Models
Jul 27, 2019 11:31 AM
sporty63
Apr 5, 2013 01:01 PM
Garcia85
Oct 12, 2010 06:53 AM
Harley Chick 1967
Apr 2, 2010 08:37 PM
KeithB
Oct 14, 2006 12:46 AM
