BOGS DOWN
Old May 26, 2008 | 03:01 PM
travis 74's Avatar
travis 74
Stage II
Default BOGS DOWN
I HAVE A 74 SHOVELHEAD WITH A SHORTY G CARB BIKE RAN FINE4 MONTHS THEN STARTED BOGING DOWN WHEN I GIVE IT GAS CLEANED TANKS AND RELINED CLEANED CARB RUNS FINE TILL GETS HOT
Old May 26, 2008 | 03:15 PM
johntheone's Avatar
johntheone
Default RE: BOGS DOWN
Check the obvious such as air leaks in the inlet manifold or carbs, valvue clearences and timing. May also be worth a check of the compression.
Hope this helps
Old May 26, 2008 | 03:19 PM
travis 74's Avatar
travis 74
Stage II
CHECKED ALL OF THEM EVERTHING LOOK FINE
Old May 26, 2008 | 04:40 PM
t150vej's Avatar
t150vej
How's the idle when it gets warm enough to bog? I'm thinking it could be (worst case) a piston seizing. That wouldn't show up on a compression test until it was really bad.
Had a chainsaw doing that for a long time. The fuel line had a small crack that opened up when it was warm. So, if it feels like it's leaning out, re-check your work.
Old May 26, 2008 | 07:36 PM
Dr.Hess's Avatar
Dr.Hess
Check the ignition. Are the timing weights free/lubed a little? Points gapped OK and not burnt? Condensor OK? Replace if there's any question. Check for intake leaks by spraying some carb cleaner around all the joints in the intake path. It's been a few decades since I messed with a shovelhead (THANK GOD), but I seem to recall intake leaks being rather common. Is the carb really clean now? Jets clear? S&S intermediate jets can block off and be a real biatch to clean out. And the main jet seems to clog rather fast too. Float level OK and the valve not sticking?
Old May 26, 2008 | 08:02 PM
89 FXRS's Avatar
89 FXRS
ORIGINAL: travis 74
Also check your plunger. It may be getting to much gas when you accelerate which will instead bog you down.
FYI. When you TYPE IN CAPS it means that you are yelling. I am sure that was not your intent so please don't do it, also it is not as easy to read all caps on our end.
Old May 26, 2008 | 08:35 PM
sqdealgeorge's Avatar
sqdealgeorge
Are you running an external gas filter?
Old May 29, 2008 | 04:33 PM
johntheone's Avatar
johntheone
One other item to check is the carb slide is moving correctly and that it is opening as vacume is created.
Old Oct 29, 2020 | 07:16 PM
handsmshovel's Avatar
handsmshovel
6th Gear
good stuff guys
Old Oct 29, 2020 | 07:19 PM
handsmshovel
6th Gear
just put mine back together after major rebuild mine was bogging as well took the teardrop off and rode it around tuning the mixture as i was riding , kept getting bogs lean and rich sides so must be a to much or nor enough or timing. ill check the flapper inside to see if its opening as well per johntheone
