Oil Leak
Old Jun 25, 2008 | 07:07 PM
dionk's Avatar
dionk
Stage III
Default Oil Leak
Have a 92 evo and it is leaking oil from the front right hand base gasket. I have removed the barrel once before and found that it is leaking from the welsh plug that is fitted to the oil gallery that runs down past the lifters to the oil pump.
Has anyone had this problem or heard of it and what is the fix.
&nbsp\\;
Cheers
Dion
Old Jun 26, 2008 | 11:24 AM
t150vej's Avatar
t150vej
Default RE: Oil Leak
I had a similar problem after accidently prying loose the plug on my nose cone when doing a cam job. I cleaned it out good with contact cleaner and stuffed the indention full of silicone rubber gasket maker/sealer - worked great.
&nbsp\\;
Unless you have the cases split, I'd be hesitant to disturb that plug. Try my trick - clean and dry with contact cleaner, pressing&nbsp\\;the journal&nbsp\\;full as possible with your finger and leaving it as flush to the block as you can. Let it set up at least overnight before going back with the jug. If you go back with paper gaskets, use Permatex Halomar. It's pricey but darn good stuff. Use a very light coat - just enough to change the color of the gasket material. If you use the expensive metal/silicone base gasket, I'd still put a tiny spot on it on the area where that plug is. You can wipe off any excess after it's all torqued down.
Old Jul 12, 2008 | 06:54 AM
dionk's Avatar
dionk
Stage III
Finally got the bike back.
The r/h case has a very fine crack in it that runs right along side the oil gallery and then up toward the back barrell. I have been told that this is a common problem on the 92 models.
&nbsp\\;
Cheers
Dion
71shovelhead
EVO
14
Oct 11, 2014 04:56 AM
TheBanditColorado
EVO
21
Oct 22, 2013 01:26 PM
RidemyEVO
EVO
May 6, 2010 01:02 PM
wbogley
Shovelhead
Jul 28, 2008 01:00 AM
cnthandledizzfxr
Jun 30, 2008 05:06 PM
