Turn signals
Old Jun 30, 2008 | 08:18 AM
roofer's Avatar
roofer
Default Turn signals
I got my 91 springer put back together and now the turn signals won't flash they just stay on but they worked when I stsrted my project any ideas on the problem
Old Jun 30, 2008 | 09:17 AM
twowheelsforever's Avatar
twowheelsforever
Default RE: Turn signals
Can you provide&nbsp\\;a little more information on what work you did between the time the turn signals worked and stopped working?
Old Jun 30, 2008 | 03:39 PM
Buddy WMC's Avatar
Buddy WMC
I was going to ask the same question as twowheels.
&nbsp\\;
Same thing happened to my 93 FXR after i removed the tank and rebuilt the top end. We&nbsp\\;found that the problem was a loose center connector in&nbsp\\;the main wiring harness under the tank (there are three connectors).
&nbsp\\;
I wire tied all three connectors together independently. It was a bitch to fish the wire ties up through each connector and took about an hour and a half. Time well spent though as the problem has been eliminated. I'm also awaiting a reported recall on some HD turn signal modules. Just installed a new one of those at $140.00 ann hope that it is O.K.
Old Jun 30, 2008 | 06:27 PM
highbars92's Avatar
highbars92
Did you add a load equalizer on the turn signals. I had to add one when I switched to the Arlen Ness signals.
Old Jul 1, 2008 | 08:06 AM
roofer's Avatar
roofer
I did not add a load equalizer. The sheeet metal has been changed out about 4 times, so I located the turn signal wires from under the seat with a test light I put the left signal on at the bars and used the test light to find the right wire and marked it, I did this for all the lights at the rear of the bike so any ideas
[IMG]local://upfiles/45641/46FB03E4FB074B47A5399CFF170DA5E3.jpg[/IMG]
Tony Underhill
Electrical/Lighting/Alarm
Apr 20, 2017 07:07 AM
TPost
EVO
Nov 21, 2016 11:53 AM
blacklabel213
Oct 20, 2015 11:14 PM
ws6lvr
Mar 22, 2013 03:04 PM
TOOTALL200
Apr 28, 2010 11:34 AM
