speedo cable lube
Old Jul 7, 2008 | 09:48 PM
blueglide88's Avatar
blueglide88
Default speedo cable lube
Anybody lubing up their speedo cable? What are you using?
Old Jul 8, 2008 | 10:43 AM
classof96's Avatar
classof96
Default RE: speedo cable lube
Mine's 13 yrs old and never did it,,,,,Damnit, I knew I missed something. Whish I would have done my trip odometer reset though, It's rusted solid.
Old Jul 8, 2008 | 11:32 AM
Dr.Hess's Avatar
Dr.Hess
Mine never seem to last long enough to worry about lubing.&nbsp\\; I'm on about my 6th now, I think.&nbsp\\; My year has the sender on the right and the cable crosses over.&nbsp\\; The next year they went to the sender on the left and they last better.&nbsp\\;
&nbsp\\;
I'm going with Dry Slide on this one.&nbsp\\; Some people say only use graphite.
Old Jul 8, 2008 | 03:19 PM
Mr1986FLST's Avatar
Mr1986FLST
On the speedo I use a heavy general puprose grease, like the grease used in the fork stem...just pull the speedo a little and unscrew cable, pull the center of the cable out and lube it, put it back in 'til it seats and screw the other end back into the speedo....
&nbsp\\;
&nbsp\\;
Old Jul 9, 2008 | 11:26 AM
mp's Avatar
mp
WD40 with the little tube.&nbsp\\; Wouldn't want the dirt that would stick to heavy grease.
Old Jul 10, 2008 | 07:31 PM
t150vej's Avatar
t150vej
Disassemble and clean the inside of the pinion regularly (every other wheel bearing service or every tire change) They get full of grit and the grease gets hard - makes a lot of weird noise when they do.
&nbsp\\;
GAA grease works well for all that..........
fogcity123
EVO
Jun 5, 2010 12:36 PM
Rynb15
Jan 23, 2009 08:32 PM
JosephGarcia
Oct 16, 2008 08:23 PM
Scott39
Jun 16, 2007 10:40 AM
bubba_d_duck
Feb 4, 2007 08:51 PM
