Fairing
Old Jul 24, 2008 | 09:29 PM
wrknman's Avatar
wrknman
Default Fairing
need help finding a wind shield for flhs fairng. also need brackets.
Old Jul 25, 2008 | 06:59 PM
sandmancustoms's Avatar
sandmancustoms
6th Gear
Default RE: Fairing
flhs only had a windshield not a fairing
Old Jan 8, 2009 | 09:15 PM
wrknman's Avatar
wrknman
mine does
Old Jan 8, 2009 | 09:56 PM
Beemervet's Avatar
Beemervet
Originally Posted by wrknman
mine does
Then how about a pic? Lots of good bikes become mutts.
Old Jan 9, 2009 | 05:21 AM
grbrown's Avatar
grbrown
Harley offered a kit for the FLHS of new brackets and batwing for a while, although I have never seen one. I bought a secondhand glassfibre batwing for my FLHS and made up my own brackets.
It is likely the windscreen is the same part number as the older FLH style, which is what I recently bought from my local Harley dealer. There are two sizes available. Brackets could be a problem, if you don't have any. If you do I suggest you restore them.
This is the larger windscreen, which I customised:
https://www.hdforums.com/forum/membe...rn-lights.html
Old Jan 26, 2009 | 07:38 PM
wrknman's Avatar
wrknman
I put the fairing on. I bought it on ebay. It was supposed to be new old stock. It came in a HD box #58374.91UT best I can tell. It's dated 9-29-92 it's the right color and even has the same pin stripe.
Old Jan 27, 2009 | 07:35 AM
grbrown's Avatar
grbrown
That is the first one I have ever come across! I thought of buying one for my 1990 FLHS, but they were very expensive at the time, here in the UK. They were introduced some time after I bought my bike new, so the part number makes sense. If you got it NOS you did well!
Your local dealer should be able to confirm which shield will fit. The part number you have will help. As I said earlier, it is probably the same as on earlier FLHs, so if you can confirm that then getting a replacement should be simple. I bought my current 80s FLH shield from my favourite Harley dealer.
As for the brackets, if the batwing is on your bike, why do you need new ones? Tell us more!
beanoboy
Nov 24, 2018 02:27 PM
apetterez
Jun 14, 2015 12:46 PM
Ridewva
Feb 13, 2013 08:54 PM
Sf hog wild
Jun 1, 2012 11:57 PM
gpp
Oct 22, 2010 09:06 PM
