I wan't some new grips and finding some with a center hole for the left grip is imposible. Can I use newer grips and just remove the end cap or the grip to check the air in the front forks ?
I guess it would depend on what kind you want. Many grips available thru HD have provisions for the valve.
And re-routing the valve/hose would be no problem however, the handlebars act as a reservoir and you would have to add some sort of tank (reservoir) in order to keep the correct air volume for proper operation of the air dampening design.
