engine change
Old Feb 24, 2009 | 06:02 PM
baldric's Avatar
baldric
Default engine change
Was'nt sure if this is the right forum.Buuuuut would an Evo engine bolt into an 82 FXR frame?
Old Feb 24, 2009 | 06:08 PM
sqdealgeorge's Avatar
sqdealgeorge
I'm going to say YES But I've been wrong before !
Old Feb 24, 2009 | 06:14 PM
miacycles's Avatar
miacycles
Maybe yes maybe no. The Early 80's FXR frames had a great difference in backbone height from frame to frame. Seeing as this was a Shovelhead the outlook is grime at best. Hope this helps
Old Feb 24, 2009 | 06:19 PM
baldric's Avatar
baldric
Thanks for the quick replies. I will definitly look into this farther.
Old Feb 24, 2009 | 07:35 PM
Dr.Hess's Avatar
Dr.Hess
It might fit if you put the whole motor in at once and didn't try to pull the rocker boxes off in the frame. Especially the back one. I'm just guessing here. I know that evos have been put in shovel frames, and if I recall, the main problem was the back vertical tube that used to hold the spring for the seat. That FXR is a rubber mount, right? You might get the ruler out and do some serious measuring.
Really, the only way to find out for sure is to try it.
Old Feb 25, 2009 | 06:51 PM
Greybeard Bob's Avatar
Greybeard Bob
Don't think so. An Evo is taller than a shovel, it would take some stretching of the frame to make it fit. JMHO, YMMV, etc.
Bob
Old Feb 26, 2009 | 10:10 AM
Teflon Tom's Avatar
Teflon Tom
Thumbs up it will fit
The FXR frame with the shovel is the same frame as the one with the EVO. I done swaps each way with no issues.
cvaria
Nov 29, 2017 11:21 AM
DonN
Oct 22, 2015 09:31 AM
Joediesel37
EVO
Dec 25, 2011 08:14 AM
El Chiguete
EVO
Dec 6, 2011 09:47 AM
REVL33
Mar 13, 2010 09:48 PM
