Would an evo engine be a direct replacement in a 82 fxr frame?
Old Dec 23, 2011 | 09:07 PM
Joediesel37's Avatar
Joediesel37
Stage II
Default Would an evo engine be a direct replacement in a 82 fxr frame?
I am going to look at a 82 fxr with an evo motor in it. What I'm trying to figure out is if he had to modify the frame at all to accept the evo? And would I have any problem bolting in an ultima motor. Thanks in advance!
Quote
Old Dec 23, 2011 | 09:11 PM
Ultra89Rider's Avatar
Ultra89Rider
The FXR frame was designed from the start for the EVO motor. When the shovel was in the frame, there was a big space between the heads and the bottom of the frame rail.
Old Dec 25, 2011 | 08:14 AM
misfitJason's Avatar
misfitJason
The frame wasn't probably modified but as far as a bolt in replacement it could be done. Little odds and ends would be changed like comp sprocket and not necessarily but hopefully they updated the primary setup and clutch
Joediesel37
Shovelhead
11
Jun 2, 2020 07:52 AM
1HappyGuy
Mar 26, 2016 01:56 PM
waynemags
EVO
May 27, 2009 02:53 PM
jaguarphenix
Exhaust System Topics
Mar 9, 2009 10:28 PM
baldric
EVO
Feb 26, 2009 10:10 AM
