Enclosed chain coversion.
Old Mar 3, 2009 | 05:31 PM
legacycycles's Avatar
legacycycles
Oops
Originally Posted by Fossil
I went to the dealers unveiling of the XR1000 and the FXRT. The good thing about the FXRT was its enclosed chain. A chain that runs in a clean oil bath has the possibility of lasting as long as a belt drive. If replacement parts for the sprockets and seals is a big problem then you may not have a choice but to change to a good O ring chain. A belt, pulleys and hardware will be much more expensive. Just keep the enclosed parts just in case you want to go back. Fossil
I will agree with you about the chain life lasting in theroy forever.However anyone has owned or does own one can tell you what a PIA they are.For starters you cant buy a rear spoocket anywhere.The rear wheel bearing are inside it.The leaks are constant.the rubber used didnot and will not hold up.Ive said time and time agin..Great idea poor execution.
Now onto my current problem.Im sick of the chain.The noise,vibration,grease,constant adj.
Not to mention the damage it done when it broke on I-95 while running 90MPH.Twice.
Granpita
EVO
Aug 11, 2014 07:35 PM
fatandgreasy
Jun 3, 2010 09:04 PM
sornamins
EVO
Sep 19, 2009 07:17 PM
Brian
Nov 21, 2006 06:02 PM
drake95th
Aug 3, 2006 01:47 AM
