SE head gaskets on Evo
Old Mar 16, 2009 | 03:25 PM
bullelkklr's Avatar
bullelkklr
Default SE head gaskets on Evo
1986 Evo
I am porting and polishing my heads and wanted to give it a little bit more compression. I took .030 off the heads and wanted another .020 - .030. I bought a screaming eagle gasket set from the local steeler in Anchorage thinking that they would be thinner than the previous gaskets I put on her.
I should have ordered a set of James - this set of gaskets are not equal to the quality that I saw from my last set of James gaskets.
So - let's get to the question. The SE head gaskets have 4 pieces of metal riveted together. 3 thin stamped gaskets and 1 thicker flat plate. I drilled the rivets and tossed the thicker flat plate, put the three remaining gaskets together in the same order as they were when new and torqued the heads down.
Am I going to smoke the head gaskets when I start her up?
Old Mar 17, 2009 | 02:56 PM
Buddy WMC's Avatar
Buddy WMC
More than likely it may, those rivets are used to hold the composite pieces of the head gasket together. I use nothing but Cometic compostite head gaskets for a couple of reasons.
(A) I have big bore cylinders, so my choices are limited.
(B) Cometic offers EVO head gaskets in different thicknesses, currently using .030.
(C) At 10.5 to 1 static, I've never had one fail.
Old Mar 20, 2009 | 05:46 PM
bullelkklr's Avatar
bullelkklr
Default Nope
didn't work. When I picked up the RPM's she blew loose. I am picking up a Cometic .035 tonight.
She did sound awesome though. I went from 90psi to 140 psi - the 3 screeming buzzard gaskets measured .028 before squish...so the cometic should put me around 130psi static - which is about where I want to be.
I think that this bike has stock bottom end in it and I don't want to "have" to replace it for at least 12K miles - I think that the hard thumping it was doing last night with this compression increase may not be best for the motor -- - but if you wanna play you gotta pay......
nsdhoward45
2014-2024 Touring Models
Mar 4, 2019 11:34 AM
rg567
Jan 21, 2014 10:27 AM
cjlandry
Exhaust System Topics
Jun 5, 2011 07:10 PM
popstheoldman
Engine Mechanical Topics
Apr 26, 2009 09:26 PM
tony2772
Apr 8, 2009 10:43 PM
