evo engine placement question
Old May 21, 2009 | 05:27 PM
abearcarver's Avatar
abearcarver
Default evo engine placement question
Will a newer 1340 evo fit in my 1985 flhtc frame ?
I want to buy a new engine but all i find are engines with the oil filter on the front.. Mine is under the engine .. ? Fit or no ?
Old May 21, 2009 | 06:36 PM
sqdealgeorge's Avatar
sqdealgeorge
Yes it will (EVO motor )
Old May 21, 2009 | 06:48 PM
abearcarver
Default no mods needed ?
I can put a New or say a 2005 NOS 1340 into my 1985 frame ? Even with the front filter ? Its a bolt up and go ?
Old May 21, 2009 | 07:09 PM
pajoe's Avatar
pajoe
On our '90 flhtcu, I kept the oil filter under the transmission when I installed a new Ultima engine which was equal to a 1992-97? Evo that has the bolt holes for the oil filter to be mounted in the front. I thought about moving it front but later decided I liked it better underneath. I did have to modify a few of the oil hoses from the tank to get them to fit the new oil pump, but they recommended changing them and flushing the oil tank during a new engine installation anyhow so it was no big deal cutting a few bends out.
Old May 21, 2009 | 07:49 PM
abearcarver
Default last year of evo
97 is the last year of the evo 1340 right ? So anything up to that date is the same as the engine i have in my 1985 ? Primary system all bolts on to the new model year engines ? ... 1984 - 1997 ?
Old May 21, 2009 | 07:53 PM
MJ's Avatar
MJ
98 was the last year of the evo in the Dynas. 99 for the rest of the models.
Old May 21, 2009 | 07:55 PM
abearcarver
Default how big a job ?
Its a job because the dam clutch and everything has to come off .. I hate that inner primary cover .. that puts everything in the pain in the *** catagory .. got to have a special puller for that clutch right ?
Old May 21, 2009 | 07:56 PM
abearcarver
so even a 1999 engine will fit my 1985 flht frame ... humm
Old May 21, 2009 | 08:15 PM
Beemervet's Avatar
Beemervet
Wrong...........
'98 was the last year Evo baggers.
Old May 21, 2009 | 08:22 PM
MJ's Avatar
MJ
I stand corrected. The Dynas and touring models was 98.
