do I need a new clutch
Old May 23, 2009 | 03:00 PM
windsoreight's Avatar
windsoreight
Default do I need a new clutch
I have noticed that the release of my clutch is at the very end of the throw. It is not slipping yet. I have tried adjusting it but no luck. Do I need a new clutch or is there a way to adjust it? My bike is a 95 e-glide.
Old May 23, 2009 | 07:32 PM
miacycles's Avatar
miacycles
Are you just adjusting the cable Slack adjuster or are you removing the derby cover and adjusting the clutch in there??
Old May 23, 2009 | 08:57 PM
windsoreight
I am pulling the derby cover and adjusting. It just bothers me that the clutch just catches at the very end of the release. The only thing I can think of is worn clutches. I was watching the pressure plate as the clutch was engaged and I have plenty of throw.
Old May 23, 2009 | 09:23 PM
mustasz's Avatar
mustasz
Whats the mileage on your bike? Usually clutch should last almost forever, I have 80.000
miles and it's OK
Old May 23, 2009 | 11:43 PM
hatchetman's Avatar
hatchetman
Go find yourself a local hawg shop & see if they have some steel disc's laying around. Add 1 as a spacer & you might get a lil more throw. I had the same issue, P.O. ran the wrong oil & they were worn out. I just bought a new set of steels & friction disc's & all was good. Easy as toast to install!
Old May 24, 2009 | 07:38 AM
miacycles's Avatar
miacycles
You need to loosen the cable adjuster all the way first. Then turn the screw on the ckutch in until it makes contact. Then back it out 1/2-3/4 turn, lock it down. adjust the cable adjuster until you have 1.8" of free play in the cable. Then it should work OK, if not then it's time to replace the clutch pack. Hope this helps.
Old May 24, 2009 | 07:58 AM
windsoreight
My bike has 69,000 miles on it. I will try to re-adjust. Thanks guys.
tylerfj24
May 28, 2019 11:19 PM
baka1969
Jun 13, 2016 09:36 AM
Wally
Jun 5, 2010 08:00 AM
Rolson1
Ironhead
May 17, 2008 08:02 AM
flyboyjacko
Sep 15, 2007 04:59 PM
