ground problem?
Old Jun 8, 2009 | 04:27 PM
capt_caveman's Avatar
capt_caveman
Originally Posted by bikerdude1903
The starter relay on my '96 is located under the fairing ... once you remove the outer fairing and stand in front of the bike my relay is located on the right hand side ... not sure if your '05 will be in the same location ... as far as cleaning, I don't know of any directions ... all I've ever done is remove the end cap with the 3 screws and use a wire brush in my dremel tool to clean the contacts ... also clean the bottom side of the ring on the plunger ... afterward I usually coat the surfaces very lightly with electrical contact grease I picked up at my local HD dealer ... I use a cheap watercolor type paint brush to apply the grease just enough for a film ... this usually will last me through the year and then I do it again during the winter ... and if I need it I have the push button ... OH, before you do the cleaning ... unhook the battery!
Thanks for the info. I did get to my manual and my relay is under the seat. I'll probably end up pulling the cover and cleaning it up like you described.
Old Jun 10, 2009 | 09:40 PM
1skrewsloose's Avatar
1skrewsloose
+1 on the dielectric grease, I use it on everything to do with electrics, light bulb sockets,etc. Just because the connections are tight doesn't necessarily mean they have good connection.
dyydjbb
Electrical/Lighting/Alarm
Oct 1, 2016 03:11 PM
TomHartrides
Apr 25, 2016 03:41 PM
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
pjb
EVO
May 8, 2012 07:15 AM
paul d
EVO
18
Aug 30, 2010 09:15 AM
