help rocker box problem
Old Jun 13, 2009 | 06:18 PM
wils5150's Avatar
wils5150
Default help rocker box problem
My middle section is shifting to the left. what causes this? and whats the fix? I am leaving foer Laconia tommorow and will have to fix it at the campground. HELP!!
Thanks Wils
Old Jun 13, 2009 | 08:00 PM
miacycles's Avatar
miacycles
A little bit of warpage can cause the rocker boxes to shift. As long as they aren't leaking center them up, tighten them down, and keep an eye on them.
Old Jun 13, 2009 | 08:32 PM
wils5150's Avatar
wils5150
they are weeping a little. I tried to center them up and with in 10 miles the middle shifted again
Old Jun 14, 2009 | 07:42 AM
HGM's Avatar
HGM
They sound loose to me. I'd remove one screw at a time, loctite them and tighten them down.. Their pretty tight with a 4" long allen wrench..
Old Jun 14, 2009 | 08:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The center section will sometimes bow out, making it impossible to get them to seal correctly. I wish they would have made the centers out of steel...
Old Jun 14, 2009 | 10:28 AM
hotrod351's Avatar
hotrod351
i have a 90 and it did the same thing, i had to heli-coil a front head bolt so the front cylinder came apart, i put all new james gaskets and it started leaking after 1,000 miles. a mech. told me to take the top and middle rocker covers off, clean them and apply permatex ultra grey, said to let it sit for 30 minutes, if i didnt let it sit i mine as well forget it. so i did as he said and that was over 6,000 miles ago. you see it a really poor design, they should of had some type of alighment pins to keep them centered butt dont, any way thats what worked for me.
Old Jun 15, 2009 | 08:42 AM
Red98RoadKing's Avatar
Red98RoadKing
While its apart take a spring loaded center punch and at a 45 deg angle punch the gaskets surface about every inch on both surfaces it will raise "teeth". Gives it some bite and the gasket should keep it from shifting. We used to have to do it to Suzuki GS1100 cam covers.
Old Jun 22, 2009 | 03:01 PM
wils5150's Avatar
wils5150
Default Update
I ended up buying new gaskets up at Laconia and put them in on a rainy day at the camp site. so far they are staying put.
1984 flhs
Shovelhead
24
Oct 30, 2018 09:00 PM
Gazzalodi
Aug 27, 2018 09:12 PM
pesnemesis
General Topics/Tech Tips
Oct 28, 2012 09:28 AM
Jethro
Exhaust System Topics
Mar 25, 2012 11:58 AM
2006FLST
EVO
14
Apr 5, 2011 12:11 PM
