Inner primary seal.
You need to replace the bearing race on the transmission input shaft (and maybe inner primary bearing also) The seal runs on that race and it's seldom you can replace that seal without the race also and keep it dry.
Transmission fluid can leak out near there also, but I figure you know the difference. I go by smell and taste myself.
geez your good!! you can tell the difference between primary oil and tranny oil! and heres me thinking you use the same oil in both??
