bore size
Old Jun 25, 2009 | 11:10 PM
waynemags's Avatar
waynemags
Default bore size
what would the safest size to bore the jugs on an 80 inch stock bike. ive got a 92 thats using oil. cant see any when starting and cant see when i decel. im guessing i put about 250 miles on and oil is down about 1/4 inch on the dipstick. did a compression test and both jugs were 160 psi. im guessing the rings are fine. thinking seals but if i tear down im thinking new rings or go up one size piston. what can i safely bore them to? thanx guys.
Old Jun 26, 2009 | 12:48 AM
t150vej's Avatar
t150vej
Increments are .005, .010, .020, .030 and Weisco makes .040 pistons but by then - you got nothing left and will have problems if you go that big.
160 compression and it's not smoking or leaking? Leave it alone. The oil level will vary with oil temperature and depending on the last several miles of the ride, they leave a little more in the bottom end at times.
Old Jun 26, 2009 | 05:04 AM
dog155's Avatar
dog155
Take this advice,it is 100% correct.
Old Jun 26, 2009 | 05:09 AM
20NightTrain03's Avatar
20NightTrain03
i agree
Old Jun 26, 2009 | 06:25 AM
waynemags's Avatar
waynemags
ill get her out for a ride this weekend and get my buddy to see if theres any smoke and go from there. thanx guys.
Old Jun 26, 2009 | 11:52 AM
grbrown's Avatar
grbrown
Before I swapped motors mine did around 1,000 miles or so on a US quart (UK quarts are bigger!).
NELS
Shovelhead
Jan 1, 2018 01:18 PM
jon loder
Engine Mechanical Topics
Jan 11, 2017 12:36 PM
jc1964
Exhaust System Topics
Oct 23, 2012 07:48 PM
RTyler7071
Aug 2, 2012 09:15 AM
supr2nr
Ironhead
Feb 15, 2008 09:10 PM
