Carburetor Upgrade
I am looking for a consensus on what is the better carb upgrade for a 1988 Softail. I have found the S&S kit, the Mikuni kit, a Thunderjet kit and then there is the option of a standard CV carb from a later model.
All comments appreciated. Thanks...W
I like the S&S because it is very easy to set up (whernever you change something) and replacement parts are easy to find.
I am running an 80" with an ev35 cam.
Looks like "F"in' translated Chinese. Sorta like directions in a dammt product ya git from them. WTF it has to do with carbs, is way the H*LL beyond me. Looks like a bowl of gobbelty-goop, to me!!!
OP, I remember something I learned decades ago (NOT that it is perfect, JUS' remember it) Walk thru the staging area of the drag strip, SEE what they are running, then go with that.
When I looked, they were running S&S.
The 'new' E's and G's are way tuneable. And I have run a ton of B's over the years.
I have an adjustable main jet Bendix/Zenith on the pan. LOVE it. ONLY complaint IS NOT the carb, BUT the "F"in' cheap azzed rebuild kits you get from China, Taiwan, Pakistan, Zimbabwae, or where ever the H*LL they come from.
CV's are GREAT carbs, too.
IMFUO, if you are used to it, know it, and can tune it, RUN IT. Makes NO SENSE to put an "E" on a scoot, if what you know and understand are CVs, or vice versa.
The S&S carburetor is my personal favorite. Once it is properly tuned, you are basically set.
