Head Torque
Old Dec 10, 2009 | 03:12 PM
onewayphil's Avatar
onewayphil
Default Head Torque
Hello, I'm working on an '87 softail.The valve cover gaskets are really leaking so I pulled the covers off and I'd like to check the head tightness. I know harley wants these tightened by the template method. However, I don't want to loosen anything. I'd rather just check to see if they are tight.Is there a set torque that I can use?.I know the '84 specs are 24-26 lb-ft. in steps. What's the diff from that year to '87?? Any help will speed up my work.
Thanks
onewayphil
Old Dec 10, 2009 | 04:48 PM
t150vej's Avatar
t150vej
There are several different step torque values given by various aftermarket gasket/engine manufacturers and dealers... HD says 7-9ft/lb, 12-15ft/lb then 90 degrees. Thing is, those values are for OEM gaskets with clean threads, washers and bosses with a light coat of oil on all.
You're wanting to re-torque/check it with the parts already having "grown together" for how ever many miles and however long. In all honesty and in with your engines health in mind, I personally have to advise you don't touch them.
But to answer your question, I just did one an hour ago with new gaskets, clean threads etc and used a follow-up, dial type torque wrench starting at 7, then 9 then 90 degrees. The torque reading on the 90 degree pull was 37ft/lb.
But again, do yourself a favor and don't mess with turning those head bolts unless you tear it down and start from scratch. Otherwise you could end up with a stretched or broken stud, threads pulled out of the engine case, warped head or blown head gasket... or ALL the above.
Old Dec 10, 2009 | 04:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the head bolts are loose, you will have leakage at the base gasket and head gasket.
If you loosen them and then re-torque them, you will have leakage at the base gasket and head gasket...
I would leave the head bolts alone unless you are ready to pull the cylinders off.
Old Dec 10, 2009 | 06:17 PM
onewayphil's Avatar
onewayphil
Thanks for the info. I kinda thought that loosening the bolts was a no-no. I'll leave them alone! I forgot that they were studs all the way through and not bolts like my shovelhead.
Again, Thanks
onewayphil
Old Dec 10, 2009 | 09:07 PM
sqdealgeorge's Avatar
sqdealgeorge
Plus one to all the above
Old Dec 12, 2009 | 08:32 AM
hotrod351's Avatar
hotrod351
35-40 torque. agree id leave them alone.
ScottinAZ
Engine Mechanical Topics
Jul 20, 2019 04:32 PM
gnaz
Exhaust System Topics
Oct 23, 2014 10:53 AM
Redbeard69
EVO
Oct 20, 2013 07:32 PM
brwdarr
EVO
Feb 24, 2010 07:45 AM
KustimKool
Sep 19, 2007 05:20 PM
