brake caliper..replace? or rebuild?
Old Dec 24, 2009 | 10:26 AM
chipdavey's Avatar
chipdavey
Default brake caliper..replace? or rebuild?
Have a 93 springer, the brakes are soft, and have bled them with no significant results, I am wanting to rebuild the master cylinders anyway, but the calipers are original equipment. HD want around $100 for a rebuild kit, and new (after market) calipers are around that price. any suggestions would be very helpful. any special tools needed for rebuilding the calipers if I decide to go that route?
Old Dec 24, 2009 | 10:29 AM
xxxflhrci's Avatar
xxxflhrci
So, how do you know the problem isn't your mastercylinder? Caliper or mastercylinder...eithe way, I would rebuild, with a kit from the aftermarket. They are much cheaper than the ones the MoCo sells.
Old Dec 26, 2009 | 11:16 AM
EVOrider's Avatar
EVOrider
I agree.....could be a several different things. I personally would try other bikes from the 90's and see how their brakes feel. That might give you a better perspective of how your brakes are suppose to feel.
Old Dec 26, 2009 | 12:59 PM
Dr.Hess's Avatar
Dr.Hess
Soft is relative. The DoT5 systems tend to feel a little softer than other systems, especially at altitude.
As far as rebuild or replace, it depends. I usually take the thing apart and then inspect it. If it is fixable, that is, not really gouged out, maybe can be cleaned with a brake hone and some emory cloth, etc., then I put a kit in. It it's shot, replace.
I recently rebuilt my rear brake, MC and caliper. It had air in it and I though the seal somewhere was bad. Took it all apart and everything looked pretty good, for 23 years and 80K miles. No corosion at all. DoT5 rocks. Put it all back together and I couldn't bleed the air out. Went through a whole bottle of DoT5 and still air in it. I finally found a very very small leak at the banjo fitting between the caliper and line. Put a new seal washer there (from O'Reilley's) and bled it in a half a reservoir worth. That junction was probably my problem from the start.
Old Dec 27, 2009 | 06:07 PM
carlgrover's Avatar
carlgrover
For what it's worth, the front brakes on my 98 RKC started to get pretty soft and lame. I took the calipers off and cleaned everything. I also greased the two pins that the calipers ride on. It made all the difference in the world. It will stop on a dime and give you change now.
Somebody posted about this as a fix for soft brakes some time back.
RomeoTango
May 28, 2020 03:40 PM
hell hound
Ironhead
May 9, 2016 07:27 PM
Sporty302
Oct 20, 2012 05:33 PM
RocketRocker
Jun 27, 2011 09:34 PM
Roadkingfatboy
Oct 2, 2009 04:08 PM
