Reuseable Oil Filter....Bunk?
Old Jan 16, 2010 | 09:37 PM
1skrewsloose's Avatar
1skrewsloose
I think W.C. Fields said, there's a sucker born every minute.
Old Jan 17, 2010 | 03:25 AM
JustDave71's Avatar
JustDave71
Pure Power filters are not "crap" and neither are K&P
Old Jan 17, 2010 | 06:44 AM
hotrod351's Avatar
hotrod351
i looked at this type of reusable filter before, not this exact one, and they look good but then i thought how much of a pain to clean it and its so much cheaper and easier to just buy a harley one and be done with it.
Old Jan 17, 2010 | 06:53 AM
FLYING's Avatar
FLYING
It is your engine,but I sure wouldn't !
Old Jan 17, 2010 | 07:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
P.T. Barnum
Old Jan 17, 2010 | 08:13 AM
dog155's Avatar
dog155
No way,just not worth fooling around with.Filters that are proven to work are cheap enough.
Old Jan 17, 2010 | 02:01 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
I have a Pure Power permanent oil filter on my bike. I am not affiliated with the company in any way. I just have the product on my bike.
Pure Power makes these for aircraft, which have far higher standards than ground-based vehicles, and also for the racing market. I figure if it's good enough for those markets, it's good enough for my bike.
It's aircraft-grade billet aluminum outside and a woven stainless steel mesh filter on the inside, that is claimed to filter down to 25 microns, or half the width of a human hair. It also runs all the oil through the filter, in contrast to throwaway paper filters that only run the oil past the paper filter, and it is claimed to flow 16 gallons per minute, which is about 4-5 times what a paper filter flows. They claim it "frees" power through flowing so freely, so the engine doesn't have to work as hard to pump the oil.
One of the cycle mags did a test of their own a few years back on it. They put fresh oil in a bike, ran it, then dynoed it. Then they replaced the oil with Pure Power oil and the permanent filter, and re-dynoed. The difference was 9 HP and about 8-9 ft/lbs torque.
I'm not saying it really does all of that, but I like the filter and the fact that it flows all oil through the filter, and cleaning it is easy. It also has fins machined on the outside which are claimed to act as an oil cooler.
Old Jan 17, 2010 | 02:50 PM
JustDave71's Avatar
JustDave71
doesn't really sound easy at all.
I always liked the idea...at the very least if we all used these we'd be throwing away less filters...but unless someone has one of those "safety kleen" type basins or something...?
Old Jan 17, 2010 | 05:42 PM
NorthGeorgiaHawg
It's a piece of cake to clean. You just unscrew the outside cover - the main body stays attached to the oil filter mount - and take out the stainless steel filter and shake it in some parts cleaner or a bucket of warm soapy water. rinse it off and shake it well to dry it, and snap it back on, then screw the outer cover back on. Takes all of 5 minutes or so to do, and nothing gets thrown away.
I didn't buy this filter primarily to be "green" though... I bought it to filter my oil a lot better than paper disposable filters do. And think it does.
Old Jan 19, 2010 | 02:09 PM
JustDave71's Avatar
JustDave71
Doesn't sound so bad. The magnets and ability to inspect the filter seem like a damn good idea, too.
hard to justify a $200 filter, though
