CV carb hiccup
Old May 3, 2010 | 03:04 PM
chardagha's Avatar
chardagha
Default CV carb hiccup
Good morning group...I recently purchased a '90 FLHTC with 37K on the clock, in excellent condition. Lately, I have had an occasional "hiccup" I am assuming from the CV carb, mainly occurring around 3100-3200 RPM, at cruising speed. Sometimes, I can ride all day with no symptoms, and like yesterday, I will get 2-3 hics, level out for 5-10 miles then more hics. This is my first CV carb, and I'm not sure where the problem lies. Any suggestions out there?
Old May 3, 2010 | 04:28 PM
miacycles's Avatar
miacycles
Sounds like a lean condition, possible vacuum leak. Check the compliance fitting on the manifold where it meets the head and the carb. Then replace the vacuum line going to the VOES and petcock. Next on the side of the carb you will see a small rod that has a rubber boot on it. It is the accelerator pump rod, sometimes these stick and cause a problem like you are describing (oops just gave away another secret!!!). The rod will stick part way down and the next time you use the throttle you wont get a full shot, causing the "hiccup". Just put a little dry lubricant like "Dry-Slide" on it and make sure it's free. Hope this helps.
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
badazdvette
Carburetor Related
Apr 4, 2013 05:44 PM
brwdarr
EVO
39
Aug 20, 2010 07:58 PM
csd4682
Ironhead
May 13, 2008 09:38 PM
Beeracuda
Exhaust System Topics
13
Dec 27, 2005 03:16 PM
