Fork oil change
Old May 10, 2010 | 07:01 PM
volksrod2110's Avatar
volksrod2110
Default Fork oil change
I have to change fork oil on a 92 FLHTC. Anybody got any suggestions on how much of the fairing needs to come apart to get to the top of the forks?
Old May 10, 2010 | 07:54 PM
t150vej's Avatar
t150vej
You don't need to disassemble anything except the drain plugs and schrader valve from the end of the left handlebar...
Release any air presure by removing the schrader valve in the handlebar end. Remove the oil drain screws at the bottom of each fork until drained (they don't hold much - 8 oz. each). To refill, apply vacuum to the air valve on the handlebar and with a drain plug screwed into the opposite side, lightly suck oil up into the forks one at a time with a small hose stuck into the oil bottle and the other end pressed against the fork at the drain hole. When both are refilled, replace the schrader valve, pump them up to 15psi or whatever and your done.... it takes about 10 minutes. (After you've found all the tools, vacuum pump and hose - still quicker by far than pulling the outer and inner fairing)
Old May 11, 2010 | 08:31 AM
sqdealgeorge's Avatar
sqdealgeorge
HD used to charge out at 6 hrs labor I was the hero I billed out at $30 plus fluid t150vej's got it down to the t
Old May 11, 2010 | 06:45 PM
volksrod2110
Good call...I didnt realize it had air suspension on the front. Thanks!
Old May 12, 2010 | 05:28 AM
Hackd's Avatar
Hackd
Originally Posted by t150vej
You don't need to disassemble anything except the drain plugs and schrader valve from the end of the left handlebar... .... it takes about 10 minutes. (After you've found all the tools, vacuum pump and hose - still quicker by far than pulling the outer and inner fairing)
What he said. The dealers don't even do it like the FSM says to. I went the FSM route... Once. Never again. I can't even imagine how much 'stuff' needs to be removed from a batwing fairing....
Dr.Hess
EVO
14
Mar 27, 2020 11:51 AM
WP50
EVO
13
Oct 18, 2011 12:26 PM
big cahuna
EVO
Jan 26, 2011 05:27 AM
tjjung
EVO
Feb 8, 2007 02:29 PM
ultrapower
Aug 23, 2006 08:26 PM
