flhs front nacel
There are four, 'Belleville' washers that hold the windshield frame on in addition to the sockethead machine screws.
Yes, the nacelle goes on the inside next to the instrument pod housing, then the spacers, then the brackets attached to the forks, and the bolts go through everything. On my bike, there is also a little clutch cable bracket that goes on the top bolt on the left fork, hanging out on the rear side of the bolt ( I tried reversing it, but my clutch would snag on the lower bolts when I turned left, and would then prevent me from being able to turn right... very dangerous! I fixed that in a hurry!) Then, the windshield brackets mount on the outside of the brackets that are attached to the forks. I also have those long triangular chrome wind deflectors on Bertha's forks that you can see in my sig pic. The mounts for those are sandwiched in between the nacelle and the windshield fork brackets... lotta layers of metal on her forks!
I wish I had known you were ordering a windshield. You won't care about this now, but maybe someone else will. Bertha's original stock Lexan (as in "not polishable") windshield was all chipped and scratched up after 15 years, and it was very difficult to see through in when riding into the sun. So, I looked around last year on the net for FLHS windshields, but had a hard time finding one. I finally found one at Cee Bailey, an aircraft windshield manufacturer. So I bought a custom-made aircraft-grade Lucite one from them for $160.
It got it in a light smoke color, and 2" wider than stock so it comes out further on the sides. You can order them stock, or 2" or 4" over wide or shorter or taller than stock, in any combination. I love the windshield - I think it looks great, and it's crystal clear. That's it my my sig pic.
Good luck!
That Cee Bailey tip is a good one! They even do a windshield for us old dynosaurs with glass-fibre batwings.
Graham - yeah, Cee Bailey are real pros... they could probably make a windshield for just about anything, given dimensions. I love the windshield... it has just enough smoke to look good, but not enough to make it too dark to ride at night safely. And I like that it's so BIG...
