A crazy loud rattle.
Old Jun 11, 2010 | 09:20 AM
  #51
Tucson_Tim's Avatar
Tucson_Tim
Congrats! And you did it yourself. Good show!
Old Jun 27, 2010 | 10:32 PM
  #52
ToWhlRidr's Avatar
ToWhlRidr
I have a 96 EGC and having a similiar problem but happens only when I use the front brake. The bike is in the dealer for some clutch problems and they said they would check it out. The dealer checked the front mount and they said it was loose. So I might go in and replace the mounts once I get it back.
Old Jun 28, 2010 | 03:13 AM
  #53
BungoBill's Avatar
BungoBill
Default 91 evo Classic Clutch & vibration problem
Im only an "expert" at what problems I have found and repaired on my bike.
My front n/side Brake Caliper had the 2 large "Allen" Bolts,which fit the Caliper on to its bracket, stuck on with Araldite/Epoxy resin,by the last/previous owner.. The threads on the Bracket had become "bare" and rather than re-thread(tap) a new thread...this is what he had done.
I suppose the point is this....before re-newing Engine Mounts or anything else
to cure Front Brake vibration,I would suggest CHECKING ALL Caliper Bolts AND brake pads making sure they are all ok and pads evenly worn. Check also that Caliper Pistons are not "sticking" and operate freely (try cleaning & "Copper" grease them . It is probably an idea to remove ALL Caliper Bolts one by one,"wire brush" them,a small touch of appropriate "Loctite" and Torque them to the Factory spec. Also worth getting Head Stock checked for "play" as the bearings might need replaced. These remedies MIGHT be more likely to cure vibration problems with front brake than new Engine Mounts. Wonder whar others think!!
Bungo.
Old Jul 4, 2010 | 11:05 AM
  #54
ToWhlRidr's Avatar
ToWhlRidr
Well, got the bike back from the dealer. It turns out the clutch spring plate separated and the rivets damaged some disks and ran a groove into the clutch basket. Now when I use the front brakes and vibration is not as bad as it was. I still plan on checking the rotors up front to make sure they are ok. But I have to also replace the Y pipe, big crack in it.
Old Jul 5, 2010 | 12:05 AM
  #55
hatchetman's Avatar
hatchetman
They all crack there. Your engine moves but your exhaust is bolted to the frame by your right boot. Take it to a welder & get it re enforced! I welded mine & no cracks for 30,000 miles!
Old Nov 19, 2014 | 12:20 PM
  #56
richard567's Avatar
richard567
check the little rubber bumper on the boomerang too...could be the thing is bouncing on the swingarm...
Old Nov 19, 2014 | 01:02 PM
  #57
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
As this is a 4 year old thread I'm fairly certain he has it fixed by now.
Old Nov 19, 2014 | 02:12 PM
  #58
bikerlaw's Avatar
bikerlaw
LOL, that was two motorcycles ago. But its all fixed, now.
Old Nov 19, 2014 | 02:40 PM
  #59
texashillcountry
Dirt don't hurt
Two motorcycles ago huh?
Did you fix it with the gas cap method?
Take off the gas cap and put a new motorcycle under it re-install gas cap!!!!
Old Nov 19, 2014 | 07:44 PM
  #60
bikerlaw's Avatar
bikerlaw
As a matter of fact, I did. The problem was the crappy motor mount design that was allowing the motor and starter to bang against the frame. It was enough to make be want another bike, even after I fixed it. So yeah, I fixed it with a whole 'nutter bike! HA!
Steel Steed
Mar 5, 2022 04:17 PM
nbowen805
Feb 8, 2018 10:43 PM
PleaseHelp
Dec 9, 2017 03:55 PM
monster715
Engine Mechanical Topics
Jul 24, 2017 09:52 AM
sarge173rd
Mar 15, 2011 12:31 AM
