Ultima 113ci oil leak from breather
Old Jun 3, 2010 | 06:39 PM
maxedout916's Avatar
maxedout916
1st Gear
Default Ultima 113ci oil leak from breather
Hey all,
I have read on here for awhile and am trying to find some solutions for this problem. I have read some other posts about the Harley Evo motors and know that this top breather leak is a problem but this is a little different case.
I have acquired a custom chopper that just came out of the shop a couple weeks ago. The 2 shops that did the work to it are not the greatest shops but it was not my choice.
I have an Ultima 113ci from 2006. It has only been run for a few hours but it is shooting oil out of the top breather behind the air breather. As I said before, I know this is a EVO thing with these top breathers but I am not sure why it is doing this as a brand new motor.
Here are my thoughts and I will be doing some checking this weekend:
1) They filled the oil too high after install and it is pumping out the excess
2) They installed the oil pump incorrectly
Does anyone have any ideas or at least a place I should start besides checking the oil level and seeing if they just overfilled it?
Thanks all!
Old Jun 3, 2010 | 06:55 PM
sqdealgeorge's Avatar
sqdealgeorge
Lets drain some of the oil out of the tank Say start with 3 gts see what transpires
Old Jun 3, 2010 | 09:22 PM
maxedout916
1st Gear
So you think I should drain out all the oil in there right now and refill it with 3 qts? Can I check it and figure out how much is in there by the fill line on dip stick?
Is that a normal thing that happens when people install a crate engine? Do they overfill the tank and would that cause the excess to come out of the breathers?
Thanks for the help!
Old Jun 3, 2010 | 10:19 PM
Jim Kraft's Avatar
Jim Kraft
Pretty easy to check if it is an oil overfill problem. Warm up the motor good, get the bike upright, pull the dip stick, and check. If it is to the top of the stick, it could very well be the problem. Use a turkey baster or something to remove enough oil to get it about half way down on the stick, and try it there. It may still pump oil out for a while until it cleans out the bottom end. You might also want to make sure your pump is scavanging the oil back to the tank. If you pull the dip stick while it is running, you should see oil coming back to the tank.
Old Jun 3, 2010 | 10:34 PM
maxedout916
1st Gear
Cool. Thanks for the advice. I have a feeling that is the problem and I am really hoping it is not something else.
I am going to check it this weekend and I will report back with updates...thanks again guys!
Old Jun 4, 2010 | 12:06 AM
jdaywf's Avatar
jdaywf
2nd Gear
I have an older Evo that had the same problem. It had a hypercharger on it when i got it with no puke tubes off of it. Sounds like your going to check the oil already but depending on the type of breater and if the engine has had alot of work done to it, it will push oil out the breather (trust me). You may want to invest in some banjo bolts. These are hollow bolts that hold the air cleaner on and screw in to the head. They have places on them where a hose can be placed on them to catch blow by oil. You can route the hoses down to the ground or bring them together and put a little filter on it. Thats what I did. Now it hardly leaks at all but it is a Harley.
skymurphy991
Oil Archive (no new posts)
Feb 6, 2013 09:08 PM
Usmarco
Shovelhead
Oct 11, 2012 07:47 PM
Bobbo
Sep 19, 2011 01:30 PM
lebert
May 29, 2010 10:17 PM
broomers
Ironhead
Jan 21, 2008 08:57 PM
