wiring passing lamps on a 1200 sportster
Old Jun 19, 2010 | 08:24 AM
Harleyonthebrain's Avatar
Harleyonthebrain
Default wiring passing lamps on a 1200 sportster
Still need some help with this! One guy said I could use a relay from a auto store and a inline fuse and that was it?? where do I wire it to??
Old Jun 20, 2010 | 07:01 AM
stevelonewolf's Avatar
stevelonewolf
Depending, In your headlamp bucket.
Old Jun 20, 2010 | 08:28 AM
Harleyonthebrain
Default wiring spotlights in a 1200 sportster
I can't get any wire's in the head light bucket!!where else can I go with the new hot wire for the spot lights??
Old Jun 20, 2010 | 08:17 PM
Dr.Hess's Avatar
Dr.Hess
Well, you could run a wire from the + battery terminal to a fuse, then to a relay, then to the passing light or other accessory, with the switch to control the relay coil wired to whatever you want.
Keep in mind that Sportsters don't have a whole lot of extra amps laying around.
Sportster Dane
Jul 17, 2019 06:38 PM
Deucedog
May 5, 2012 09:31 PM
Dustmaker
Apr 12, 2012 05:02 PM
zappaco1
Electrical/Lighting/Alarm
Dec 16, 2010 08:34 AM
vafatboy07
Feb 20, 2008 07:27 PM
