Speedo replace
Old Jun 25, 2010 | 09:21 AM
tujo33's Avatar
tujo33
Default Speedo replace
I just got my new speedo in and it has a blue wire coming out of it. Stock one has no wires coming off it. I was thinking its for illumination but not too sure. Any one else got ideas. Thx.
Old Jun 25, 2010 | 11:52 AM
Mr1986FLST's Avatar
Mr1986FLST
What bike do you have? I last replaced my speedo around '02 ...I think there was one wire and if I remember right it goes to 2 or 3 lights in the speedo for my 86 flst.
Old Jun 25, 2010 | 12:02 PM
tujo33's Avatar
tujo33
its an 88 fxsts. im just not sure which lead i should be puting it on the ignition. my manual dont show and there was no info. provided iwth the box
Old Jun 28, 2010 | 09:16 PM
Uncle G.'s Avatar
Uncle G.
If the speedo is for a '91 or later, it will have a short wire coming out of a rubber grommet which runs from the reed switch in the speedo to the turn signal module to tell the turn signals when to shut off. If you try to use a '91-'95 speedo on an '88, you'll find that the trip odometer reset **** won't line up with the hole in the dash cover, and you'll also have to source a '91-'95 dash cover as well.
The only other wires on the mechanical speedos go to one or two lamp sockets located at the 12 o'clock and 6 o'clock positions of the dial. The sockets snap in and out with a sideways push.
Harvey2013!
Jan 9, 2014 01:37 AM
jreichart
Dec 24, 2012 08:42 PM
bh76
Aug 20, 2012 04:20 AM
dukester
EVO
Jan 11, 2010 09:54 AM
hdwillow
Jun 27, 2007 12:08 AM
