rocker cover
Old Jul 5, 2010 | 07:55 PM
RidemyEVO's Avatar
RidemyEVO
Take the rocker cover to a good welder he can fill it and drill and tap a new hole. I did this with my front head when the exhaust stud pulled out.
Old Jul 6, 2010 | 07:59 PM
j.m.s.'s Avatar
j.m.s.
It's not running right now. Very hard to start, rear cylinder exhaust sounds different than front and has a pop in its rhythm with smoke. Compression test shows 120 for front and 75 for rear, if I try a few times it sometimes hits 120, but not consistent like front cylinder.
Joe
Old Jul 6, 2010 | 08:33 PM
hatchetman's Avatar
hatchetman
Pull your rear cover off & roll the engine over with both plugs out. Pay attention to the valve movement. i think you have an intake sticking open for some reason.
Old Jul 7, 2010 | 05:38 AM
Hackd's Avatar
Hackd
Originally Posted by j.m.s.
...Ultimately I have to get a new lower rocker cover, the threads are stripped.
Well, the good news is that The MoCo sells them individually, not as a set. Which will save some $$$. Also, the lower is the least likely to be warped, so a used one may be a good option.
Old Jul 10, 2010 | 09:04 AM
j.m.s.'s Avatar
j.m.s.
It ends up you can not put longer bolts in the primary side of rocker cover, they hit the valve spring. After getting it started it needed some carburetor adjustments and then it was fine. Used red locktite and it seems to be holding, no more oil leak, for now!
rydahog
Engine Mechanical Topics
Jan 22, 2018 02:32 PM
left4dead
EVO
19
Aug 4, 2015 07:04 PM
Stag556
Jul 27, 2012 12:25 PM
flyburch
Nov 24, 2009 04:22 PM
cj9581
Exhaust System Topics
Feb 4, 2007 01:56 PM
