DIN raido
Old Jul 17, 2010 | 11:18 PM
gnafin's Avatar
gnafin
Default DIN raido
Hmm how do i install a DIN type raido in my 87 faring?
Old Jul 18, 2010 | 01:36 AM
Ultra89Rider's Avatar
Ultra89Rider
Change the inner/outer Fairing and mounting brackets. They will bolt right up.
Old Jul 18, 2010 | 04:02 AM
MDodson's Avatar
MDodson
What is a DIN radio?
Old Jul 18, 2010 | 04:51 AM
Ultra89Rider
The Factory radio Harley used in the 1986 -1988 models had the two studs with the rectangular box in the center, like the older radio with the volume stud on the left and the tuning stud on the right. The DIN is the radio that is entirely in the full rectangular box. No studs or side holes.
The Harley radio looked like it was a DIN type of a slip in radio. The front panel plugged in and covered the studs. The cassette opening was in the center of the panel.
Old Jul 18, 2010 | 06:58 AM
Dr.Hess's Avatar
Dr.Hess
Cut out the fairing opening to make it fit your DIN mounting system. Just takes some time with a Dremmel brand Moto Tool. You have to pull the outer fairing off to get in there for the electrical stuff, so that's a good starting point.
Old Jul 23, 2010 | 12:41 PM
IDIDNTDOIT's Avatar
IDIDNTDOIT
Hey gnafin.... I can walk you thru the mounting of it and i have some of the pieces to do it. You alter the original bracket for behind the fairing, buy an new rubber nosecone and weather cover (still available thru HD) and madify the rear bracket to support the radio if you have to, my radio plug hit it in the rear. I can have the guy modify the plate to be like mine if you like... if you have a wirefeed you can do it. Let me know, I will hold off sending the signal cancell till I hear.
Bill
Old Jul 23, 2010 | 02:28 PM
MDodson's Avatar
MDodson
I have a inner fairing from my 91 I would sale cheap still has radio and gauges in it. The wiring harness except for the radio was ate by mice . I could get some pictures and e-mail them if you like.
Old Jul 26, 2010 | 07:58 AM
gnafin's Avatar
gnafin
i found a raido that will fit so i think i am all set... nice thing is i can use usb or SD memory... nice... but still like to try out the flasher thing....
Bill
Old Jul 29, 2010 | 12:08 AM
IDIDNTDOIT's Avatar
IDIDNTDOIT
Hope to get that out to you yet this week.
panheadscooty
Audio Systems
Oct 19, 2015 11:06 AM
h-d wrencher
Audio Systems
Aug 13, 2015 09:41 PM
mdanehart
2014-2024 Touring Models
Jan 18, 2015 06:12 AM
ny2az
Touring Parts
Oct 13, 2012 06:34 PM
Softtail Bob
May 4, 2007 07:54 PM
