EVO FLHTC Consideration
Old Aug 22, 2010 | 10:35 AM
grbrown's Avatar
grbrown
Originally Posted by elreplica
Thanks dude.. I was informed that it did have the Stage 1 air breather with the modified jetting and the Vance & Hines slip ons...I have suspected jetting issues but am not that up on tinkering... would the Andrews EV 27 cam possibly rectify this? It seems you think it would...and is much appreciated advice to go forward with...
A change of cam will improve breathing of the engine and may need changes to the carb to get the best out of it. So no, it won't sort out your current problem, possibly add to it. If you are not confident of tinkering find yourself an independent who can sort your bike for you. Changing a cam is not very time consuming or expensive, so you could offer that as a carrot!
Old Aug 23, 2010 | 06:55 AM
elreplica's Avatar
elreplica
3rd Gear
Default clock settings
I can't seem to set the clock on my 96 FLH...doesn't seem to say anything in the owners manual...
Old Aug 23, 2010 | 09:46 AM
grbrown's Avatar
grbrown
Mine has a plastic **** in the middle of the face. Normally it just turns without doing anything. Press it in and gently turn it. You should feel it engage the hands and turn them. If you have big fingers find a friendly pair of small gentle ones to do it!
Old Aug 24, 2010 | 10:16 AM
98fat's Avatar
98fat
I think 95 and after solved some of the old evo problems, base gaskets, etc... Still have the inner cam bearing to solve but pretty easy to do and need to replace the lifters most of the time anyway.
Amos Iron Wolf
EVO
42
Jul 18, 2017 05:48 AM
Mauidaid
Sep 11, 2014 02:40 AM
axlespacer
EVO
41
Nov 19, 2013 11:28 AM
MJHJEA
Mar 14, 2012 12:36 PM
Thewaxmania
Aug 13, 2010 10:31 PM
