engine light
Old Aug 22, 2010 | 05:42 PM
chuckjr's Avatar
chuckjr
1st Gear
Default engine light
How can I get the codes off a 96 flhri or can I buy a diagnostic test lamp to read them
Old Aug 25, 2010 | 04:12 AM
96roadking's Avatar
96roadking
Do you have a HD manual? IF not, I'll look thru mine and see if I can help. I haven't had the issue, myself.
Old Aug 25, 2010 | 06:06 AM
EVOrider's Avatar
EVOrider
Turn the ignition to on.......then off......then on.....then off......then on
The engine light will flash quickly.......for its own system check.
Then it will throw out the codes......for example, (beep, pause, beep) means 11. If I remember correctly, 11 means there are no codes set. Search around on the internet and you'll be able to know what the codes represent.
Old Aug 28, 2010 | 07:44 PM
chuckjr's Avatar
chuckjr
1st Gear
Thanks for the help had to codes 33 and 14 fuel pump relay and temp sensor
Old Aug 28, 2010 | 10:54 PM
RidemyEVO's Avatar
RidemyEVO
Ahhh just curious but what year of EVO did trouble codes start to be available, I always thought it was only with the twinkies?
Old Aug 29, 2010 | 05:16 AM
96roadking's Avatar
96roadking
I think that they started when EFI got put in touring bikes, my 96 has them. I believe the very first EFI bikes were in 95.
Old Aug 29, 2010 | 07:21 AM
EVOrider's Avatar
EVOrider
I would start with checking any wiring on the bike first. Make sure everything is tight and secured. If the wiring seems ok....
It is possible the engine temperature sensor went bad setting other codes off. Definately start with this sensor.
Old Aug 29, 2010 | 10:19 AM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
Reading this thread makes me appreciate the fact that Bertha has just a simple CV carb, and no electronics other than the ignition module... my simple mind can deal with that!
Hope you find your answer...
Old Aug 29, 2010 | 10:33 AM
RidemyEVO's Avatar
RidemyEVO
Thanks for the info, always nice when I learn something new.
Old Aug 29, 2010 | 12:08 PM
NorthGeorgiaHawg
It sure is! But my problem is that I have to be more and more selective about learning new things, because I don't have that many unused brain cells left to store them. I wish I could forget a lot of the useless CRAP that is just sitting around in there, taking up valuable storage space!
