battery relocation
Old Jan 26, 2011 | 01:33 PM
grbrown's Avatar
grbrown
Originally Posted by shovhd
I also want to do the 6 gal fuel tank swap (how is that coming along, Graham?).....
I haven't touched it of late. I have come up with a better rear mounting, which I need to get a pal to make, when he has time. I also now have a fuel level sender which I hope to get mounted in the tank and working. I originally thought I would try mounting a similar one to my Evo in the tank, but that doesn't seem so feasible now. I have primed my brother to help sort out mounting the new one (I have my skilled artisans lined up!). Hope to get back into meddling with it soon. Then it will be remodel the nose of my saddle to match it.
Old Apr 20, 2011 | 08:50 PM
10Seconds's Avatar
10Seconds
I am a latecomer to this threat but thanks so much for the info, I am looking to do the same think to my 1984 FLHTC and this has helped a ton. I am subscribed and cant wait to hear how all of this comes together for you.
If I understand right, I will have to relocate the oil reservoir also to fit the battery under the seat? Or were you just doing that to upgrade the tranny?
Old Apr 28, 2011 | 11:03 PM
hotrod6779's Avatar
hotrod6779
Let us know how the 93 battery tray works. You've got me excited
Old Apr 29, 2011 | 08:00 AM
perpulreaper's Avatar
perpulreaper
Broke still have the newer bag with the older battery cutout and if so want to sale it
Old Apr 29, 2011 | 08:38 AM
grbrown's Avatar
grbrown
Seems to me it must be possible to find a battery that will fit in beside the existing oil tank, that will squeeze in. I can see scope to build a custom tank in the space around a 93 battery, skills permitting. I wouldn't personally fancy fitting a later trans to get rid of the oil tank, that seems a step too far!
Old May 30, 2011 | 08:00 PM
broke c7's Avatar
broke c7
Originally Posted by grbrown
Some pics of your battery and saddlebag mods would be very interesting! Next time you have a camera in your hand....
okay, finally got the thing running. had to replace the starter, after i bought, ground and modified a new solenoid repair kit. so much for my diagnostic abilities. anyway as promised, here are some photos of the battery relocated under the seat and the "93 saddlebag mount. of course none of the parts got painted. photo 0165 shows the 2002 road king seat in place. LePera and love it. photo 0167 shows the bracket. the white lines are just silicone strips (bathtub silicone)that separate the battery from the bracket and absorb vibration. 0168 shows a sportster size battery in the bracket, 0166 shows the battery panel cut back with the '93 bag behind it. all i had for trim when i did this on a holiday was fuel line, never changed it after that. 0169 shows how i had to move the rubber mount on the '93 bag back an inch or so to land on the support. 0170 is a bit of the battery tray that needed ground away, 0171 & 0174 shows the battery panel cut out, 0172 is new rear bracket, 0173 is new front bracket bolted to old bracket, 0175 shows the fillers that cover up the fact that i did not paint anything
Attached Thumbnails battery relocation-dscn0165.jpg   battery relocation-dscn0166.jpg   battery relocation-dscn0168.jpg   battery relocation-dscn0167.jpg   battery relocation-dscn0169.jpg
Old May 30, 2011 | 08:08 PM
broke c7's Avatar
broke c7
here are the rest of the photos. a computer guy i am not.
0170 is a bit of the battery tray that needed ground away, 0171 & 0174 shows the battery panel cut out, 0172 is new rear bracket, 0173 is new front bracket bolted to old bracket, 0175 shows the fillers that cover up the fact that i did not paint anything[/QUOTE]
Attached Thumbnails battery relocation-dscn0170.jpg   battery relocation-dscn0171.jpg   battery relocation-dscn0172.jpg   battery relocation-dscn0173.jpg   battery relocation-dscn0174.jpg
Old May 30, 2011 | 08:15 PM
10Seconds's Avatar
10Seconds
Thanks so much for sharing those pics, thats some creative and awesome work right there.
Old May 31, 2011 | 03:06 AM
grbrown's Avatar
grbrown
Broke, you're a star! Thanks for posting pics, that'll get the old grey matter turning over....
Old May 31, 2011 | 10:17 AM
az426hemi's Avatar
az426hemi
3rd Gear
Hey Broke, from what I can see you have a fiine looking ride. Can you post pics of your bike. I like what little I can see. I am getting ready to redo my 89 FLHS and I would like to see more of your bike
