93 flhs front suspension
Old Sep 21, 2010 | 04:09 PM
Tactical111's Avatar
Tactical111
Lost the air assist feature on front forks of my '91 FLHS when I replaced my handlebars a couple of years ago. Without the air pressure the front OEM springs were sloppy and weak; slamming to bottom on the slightest bump. Had the Progressive "variable rate stock height" fork springs installed which really firmed up the front end just right; firm but responsive. Also got rid of the "bagger wobble" with the Glide Pro swingarm isolator/front motor mount kit and went to Custom Cycle S.S. cleave bearings to replace the OEM rubber crap on the inside of the swingarm. Tight, responsive, and now predictable suspension. No need to buy a post 2008 bagger to get tight suspension if you make these or similar changes IMHO.
Old Sep 21, 2010 | 04:47 PM
grbrown's Avatar
grbrown
The air assist on my 1990 still works! Owned it from new. I keep around 15psi in it for solo and closer to 20psi for 2-up. I've never ridden it with no air, but would expect the ride to be very soft. Would be OK if you're very light, but fitting stronger springs is probably essential.
You could phone Progressive for their advice on a set of springs. They are an HDF sponsor, so might even offer a discount?
Old Sep 22, 2010 | 06:15 AM
ranger fan's Avatar
ranger fan
Good advice guys! Thanks!
Old Sep 22, 2010 | 07:37 AM
89FLHT's Avatar
89FLHT
I've searched on google - is there a link for the Custom Cycle S.S. cleave bearings ?
to date and for the OP - I've also removed the entire wiring and plumbing for the air assist front end and installed progressinve springs with 20 wt oil and a pair of progressive shocks for the back, it has made a world of difference in the handleing.
I intend to install the glide pro system this winter , but would like to replace the cleave blocks at that time. Those bearings seem to be a good way to eliminate the worn out cleave blocks.
Old Sep 22, 2010 | 08:01 AM
grbrown's Avatar
grbrown
Cool
We are spoiled for choice with these things! Other sources of new hard bushes are Motorcycle Metal, True-Track and Sta-Bo, that I know of. There are even more brands of stabilizer.
I have a True-Track Trackula kit on my 1990 Glide. Comes with bronze swingarm bushings, new mounting rubbers all round, plus rear stabilizer. Everything in one parcel. Original and best!
Old Sep 22, 2010 | 09:09 AM
rivercityslim's Avatar
rivercityslim
I have the same on my '89. Along with new Progressive shocks and Progressive 'variable rate' fork springs, it tightened the suspension up considerably, with a corresponding increase in handling confidence. The ride is not quite as 'plush', as you might expect with stiffer suspension, but the improvement in handling is well worth it. The jury is still out on the Progressive shocks; I compromised there due to budget constraints. Next year I may take the plunge and invest in the Ohlins.
Old Sep 22, 2010 | 01:00 PM
Tactical111
Thumbs up Cleave bearings...
www.jpcycles.com has the kit for around $250 includes the guide bushings. You won't be disappointed with the Glide Pro set up as no bolt on fix; it attacks the origin of the problem; the OEM soft rubber "isolator" rear motor mounts.
Old Sep 22, 2010 | 01:56 PM
89FLHT's Avatar
89FLHT
Thanks to all of you for the assist !
Old Sep 29, 2010 | 12:13 PM
dz1087's Avatar
dz1087
Originally Posted by ranger fan
So I can jusy lose the air parts and it should be fine? I want to change the handlebars and I put a roadking nacelle on the front. It all fits but it's kinda close. The nacelle scrapes the solenoid.
Hey, how's that look? The Road King nacelle? I've been thinking of doing that myself.
Old Sep 30, 2010 | 07:19 AM
ranger fan's Avatar
ranger fan
Looks great! Ill post pics as soon as the rain stops.
