Storing your bike for the winter
Fuel System: We recommend the use of a fuel stabilizer to keep your gas fresh and to protect your carbs and gas tank from corrosion and residue deposits. STA-BIL Marine (#53-0055) has been reformulated to offer double corrosion protection as well as protection from the ETHANOL additive in gasoline. Fill your tank and add stabilizer using the directions on the bottle. Run the engine for a few minutes to circulate the mixture in to the carbs. Fuel
injectors are less affected but still greatly benefit from this additive. Get the big bottle!! It works great in Lawnmowers, Jet Skis and Snowmobiles also.
Tires: Tires are affected by heat, sunlight and dampness, as well as ozone, which is given off by electric motors. Keep your bike out of direct sunlight and away from electric motors such as refrigerators, freezers, etc. Store your bike with the tires fully inflated in a cool dry place. Use a center stand to keep weight off the tires.
Battery: The easiest way to prolong battery life is to keep it fully charged. We recommend the BikeMaster 365TD (#15-0917) which works well on all batteries including the new TRU GEL models. We also carry the BATTERY TENDER and YUASA chargers. All of these chargers can be left plugged in indefinitely and will self regulate to keep the battery charged. USE CAUTION!!!! Follow the manufacturers instructions when working with your battery.
Lubrication: During regular use, your engine oil becomes acidic from combustion. Prior to storage we recommend that you change your oil and filter, and run the engine for a few
minutes to circulate the new oil. You may want to change it again in the spring as condensation can form in your engine during the cold weather. It is also a good idea to apply a liberal coating of lubricant to your chain. Cables, lever pivots, linkages, etc. can be protected against corrosion using Motorex Anti-Rust or Maxima MPPL.
General: It is a good idea to cover your motorcycle during storage. We carry the COVERMAX line of covers as well as covers by DOWCO. Also, a good washing followed by a liberal coating of wax or polish is an excellent way to protect your investment during the
winter months. Products from S-100 or Original Bike Spirits work very well.
Hope this helps.
Plus 1000 on the Stabil.
We put it in all our bulk gas cans for all our farm equipment, mowers, weedeaters, chain saws, pressure washers, etc.
A few minutes time and a few cents worth will save you lots of frustration when you start doing the honey-dos in the spring and your small engines crank right up instead of the more expensive alternative.
