Carb issues
Old Nov 17, 2010 | 04:56 AM
FMSMRED's Avatar
FMSMRED
Stage III
Default Carb issues
1985 FLHTC. I have been having issues with idling I belive I have it worked out. Now I have a poblem with the accelerator, it dose not work. Recently rebuilt. Any help would be appreciated.
Old Nov 17, 2010 | 04:58 AM
FMSMRED's Avatar
FMSMRED
Stage III
Default Carb issues
Sorry carb type, Kehine (Butter-fly type)
Old Nov 17, 2010 | 06:32 AM
pjb's Avatar
pjb
do you mean the butterfly assembly doesn't move? If so, you're going to have to locate whatever is binding it up.
I have the original carb on my 85 FXWG. It runs fine but I'm upgrading it to an S&S. PM me if you're interested in the one I'm taking off.
Old Nov 17, 2010 | 01:13 PM
FMSMRED's Avatar
FMSMRED
Stage III
Thank you, no everything is free, its just when I put her in gear an release she falls flat on her face. Why are you upgrading ?? If you don't mind my asking. Interested? hell yea! I would be happy to take it off your hands. It has become some what of an all consuming quest, I rebuilt it (carb) my self the reason was it just would'nt idol and it would back fire thru the carb. The only thing that I could find wrong was the slow jet was pluged. I had no accelerator prob before but now I do!!! It seems that every time I find a prob an correct it I cause a new one. Thanks again for your input...
Old Nov 17, 2010 | 01:28 PM
pjb's Avatar
pjb
did you check the rubber compliance fittings, they are known to go bad and can cause lots of problems.
I have had my 85 FXWG since new, and the motor/carb etc.. are stock original. After having a couple of Ironhorse choppers for the last several years the 111 motor makes the evo seem weak. The kehin butterfly is known to be pretty crappy at best. I have bought an S&S E carb, because the S&S is easy to work with and I like the G's my choppers have. Also got an Andrews EV27 cam, lifters, adjustable pushrods, cam bearing, and gaskets to do it all at once.
old carb is in good shape and has an S&S air cleaner on it. PM me an offer for the whole setup, including intake and compliance fittings.
Old Nov 17, 2010 | 03:13 PM
woodnbow's Avatar
woodnbow
Also double check the accelerator pump, if it's not properly installed it'll give you those problems. I like the Keihin butterfly ok. Properly jetted and tuned they run just fine on a stock motor IMO...
Old Nov 17, 2010 | 03:54 PM
BB4xl's Avatar
BB4xl
I had surgery one year and my bike sat for a while. When I went to ride it would idle ,but when you gave it gas would sputter. The little rod that makes the Acc pump squirt had a little corrosion on it. I took it off and cleaned it with 400 sandpaper. Was good to go then. This was on a Screaming Eagle carb. I forget who made it.
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
RSDUDA
Shovelhead
Dec 29, 2014 02:37 PM
benoit
Exhaust System Topics
Jul 8, 2012 03:52 PM
droff85
Ironhead
Mar 13, 2009 12:02 PM
Beeracuda
13
Dec 27, 2005 03:16 PM
