Top End
Old Dec 8, 2010 | 10:41 PM
hatchetman's Avatar
hatchetman
Originally Posted by gartec81
i wish i new enough to do the job myself. i think i need to take a class or something. cause i have no one to learn from. i get the local shop mobtown cycle to do the motor work. hos did you all learn
You can buy the CD's on line that go step by step on a tear down & re build. That plus the manual make that job fairly strait forward.
putting your location on your profile will tell anyone who might be into helping you, if your local to them.
Hatch.
Old Dec 9, 2010 | 02:23 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by tc
Thought about dropping engine, but front mount is on top of a welded cross bar on the front down tubes, and don't much like getting into dropping rear and gearbox!!!!!
Also did same job on a Sporty a few years ago and do not remember having this problem.
Thought about EV27 but undecided if it is worth effort/money. They are very expensive here in Ireland and with the present economic situation here and a new budget just being passed, money tight. Unless someone there has a "free Sample" or a cheapie.
Tony
The EV-27 will wake your bike up. Where there is a will, there is a way.
Old Dec 10, 2010 | 01:48 AM
Gutman's Avatar
Gutman
That rocker will go in easier than it came out. Have patience. Def make sure ALL surfaces are flat including cylinder base. Take to a machine shop if necessary. Use Torque plates if honeing the cylinder's and verify ring gaps. Use viton seals and no sealant on any gasket surface.
Old Dec 10, 2010 | 02:07 PM
96roadking's Avatar
96roadking
Some guy was posting an EV27 for sale for 80.00 in the for sale section. said he bought it and changed his mind to an EV13.
Old Dec 10, 2010 | 04:37 PM
tc's Avatar
tc
Is'nt this a great site and forum?
I suppose it is one of the reasons I love my Harley, old and all as she is, even in these days of doom and gloom there is so much assistance and help from other Harley riders, and all free!!!!!!!!!!!!!
Thanks to all for advice, it has all been taken on board.
One other question. The EV27 is advertised as a simple swop, is it?
If I got one, can I literally just remove my old one and replace it with this, no pushrod or tappett swop, just cam for cam and a new gasket?
Thanks again , I am sure I will get loads of answers, but as my signature says, "I like simple".....................
Cheers
Tony.
Old Dec 10, 2010 | 05:49 PM
IronGear's Avatar
IronGear
Originally Posted by miacycles
Ironbutt nailed it. You have to have patience, remove the rocker arms take all the bolts out comepletely and have patience. Removeing the front mount will give you some additional clearance as well. When re-assembling use metal gaskets where available. I would also reccomend file-to-fit rings as most of the "drop in" rings have a huge end gap and don't hone too much or you might get some "piston rattle". Hope this helps
Can you please advise how to remove the front mount on a 1987 FLST.
That piston rattle bit is hilarious. Go a bit longer, and give yourself a rebore.
Old Dec 10, 2010 | 06:06 PM
miacycles's Avatar
miacycles
With a torch or plasma cutter LOL !!! Sorry for the brain cramp, but the days have been long and busy. Thought it was a rubber mount. That's one of the hazards when the post get lots of replies and you try to remember what was said by whom.
Old Dec 11, 2010 | 01:37 AM
IronGear's Avatar
IronGear
Cheers
Tony.
Yes, lots of assistance, but be a little wary.
When you know little, you can easily be misled.
Most of what I read on here is basically wrong.
So take care.
Old Dec 11, 2010 | 01:40 AM
IronGear's Avatar
IronGear
When I post, I just normally state the facts, without a bit pile of oiling words to soothe fragile egos. That's their problem. I just could never be bothered.
I do take the time to tease you a little though, as you are not only generally on the right track, but can respond with an interesting view.
Old Dec 11, 2010 | 01:21 PM
hatchetman's Avatar
hatchetman
So take care.
If you think a reply here is the wrong advise & could cause the OP to damage his EVO, Maybe you could point out what you think is the wrong advise.
you have the floor!
hatch.
