Ignition question
Old Dec 20, 2010 | 10:32 AM
FATBAGGA's Avatar
FATBAGGA
Default Ignition question
I have a 97 fatboy with the screamin eagle ignition. I just rebuilt the complete engine with new rod assembly, bearings,pistons, rings,seals and gaskets and noticed the pick up in the nose cone for the ignition was leaking a liquid from it. The question is can I replace it with a stock pick up or do i need to replace the entire ignition box and pick up. I heard it comes as a matched set. Thanks for any help.
Old Dec 20, 2010 | 11:37 AM
Dr.Hess's Avatar
Dr.Hess
If what you have is a SE ignition module, then you should also have the original pickup in the cone. Just replace that with another OEM one.
Old Dec 21, 2010 | 05:37 AM
miacycles's Avatar
miacycles
The doctor has given you some sound advice!!!
Old Dec 21, 2010 | 06:00 AM
RidemyEVO's Avatar
RidemyEVO
I don't have my manual handy at the moment but keep in mind it doesn't take a whole lot of torque to distort the cup bolt surface so double check the torque spec. Touch of blue lock tite goes a long way.
jnorbros1
Dec 3, 2014 11:57 AM
matto371
Sep 8, 2012 11:28 AM
Tltrump
Jun 28, 2012 06:51 PM
jimjam31
EVO
15
Jan 26, 2012 08:43 PM
Terp84Alum
Jun 9, 2010 06:03 AM
