Need help troubleshooting!
Old Dec 30, 2010 | 09:28 AM
Edster 69's Avatar
Edster 69
Default Need help troubleshooting!
Hey guys need some input. I have a 97 Roadking and the last few times I rode it I get this popping sound that comes from the carb area? It happens when I'm in and around 100km-120km. Any speed before 100km or above 120km I never get that pop. It definitely isn't coming from my pipes so I've ruled out running to lean or rich.
TIA
Old Dec 30, 2010 | 09:38 AM
Dr.Hess's Avatar
Dr.Hess
Is this EFI or carbed? In general, popping from the carb is a sign of too lean. You could have an intake leak. If carbed, you could have a gunked up main or intermediate jet, depending on what carb you have.
Popping from the exhaust pipes during deceleration can be an exhaust gas leak.
Old Dec 30, 2010 | 09:45 AM
Faast Ed's Avatar
Faast Ed
I agree that popping out the carb is lean.
Cooler weather requires a richer mixture sometimes.
Old Dec 30, 2010 | 09:54 AM
Edster 69's Avatar
Edster 69
Dr.Hess it's carburated. How many turns out would you recommend? Also if I had a leak how would I check or what visible signs would there be?
Old Dec 30, 2010 | 11:06 AM
topfuel7's Avatar
topfuel7
Spray WD40 around the intake seals while the bike is running and see if the engine changes RPM. If it revs slightly then you have an intake seal leak.
Old Dec 30, 2010 | 11:50 AM
Dr.Hess's Avatar
Dr.Hess
Yes, as topfuel7 says. Carb cleaner works too, and listen for the RPM change, up or down. Spray a little on all the joints between the carb and the head while running.
As for adjusting the carb, I don't know CV carbs, just S&S and Megasquirt EFI. If this is a new problem, I would think that something is wrong and needs fixing, versus just needing to be richened it up and mask the symptoms. Start with a good cleaning (with a soak) and go from there.
Old Dec 30, 2010 | 01:27 PM
hatchetman's Avatar
hatchetman
I think your float bowl is going empty with sustained rpms. Check float height.
Does the engine run well in town or slower on secondary highways?
Check your plug colour after a normal ride going 60mph for an hour. That might tell you where your fuel/air mixture is!
Hatch.
Old Dec 30, 2010 | 02:07 PM
Edster 69's Avatar
Edster 69
Thanks guys I really appreciate the input.
Old Jan 9, 2011 | 05:30 PM
89 TA's Avatar
89 TA
Did you ever figure out what was wrong?
Old Jan 10, 2011 | 04:56 AM
HGM's Avatar
HGM
I'm thinking that since its at higher speeds, your running out of fuel. I'd check the pet-**** screen.. With the ethanol in Georgia, I've had some and heard a couple of buddies have a few problems..
