need some help with evo
Old Feb 22, 2011 | 06:38 PM
chuckw2's Avatar
chuckw2
Originally Posted by houseoutnumbered
I went ahead and rebuilt the carb and glued in the intake with hylomar.
fired the bike up ready to go and the same crap, warms up and stumbles.
started to go through the manifold, the carb gasket looked real good.
I decided to put on a vac pump and check the VOES.
the voes wont hold a vaccum, i can get it to reach 5inches of mercury but it wont stay.
also found the vaccum line to the petcock had a hole.
so my question is this shouldnt the voes hold vaccum, not leak it off.
It will build up to 5-6 inches but then dropes off??????
thanks everyone for the help!
I do appreciate it...
VOES advances the timing. It should hold vacuum. Vacuum leak is probably causing your problem. Someone please correct me if I'm wrong.
Old Feb 22, 2011 | 07:53 PM
the blob's Avatar
the blob
if you got a vacuum leak at the petcock it will not flow fuel!
Old Feb 23, 2011 | 06:02 AM
houseoutnumbered's Avatar
houseoutnumbered
Blob, it wasnt a very big hole at the 90 off the petcock, (but it still was a hole).
the vaccum pump could get the vacuum to 5 and 6 inch mark but would not hold.easy fix under a 100.00 bucks to fix, just have to wait for the parts to ship.
Old Feb 23, 2011 | 06:12 AM
Mike T's Avatar
Mike T
Any hole in the petcock hose is too much. Change that line.
Old Feb 24, 2011 | 06:38 PM
Jim Kraft's Avatar
Jim Kraft
If yours is like my 99 EVO, the vacuum line goes to the VOES, and tee's off from there to the fuel valve. So a leak anywhere will cause a loss of vacuum at both of them.
Old Mar 6, 2011 | 04:36 AM
emwolb's Avatar
emwolb
any sort of hole in the vacuum line means that it's not making your voes work properly would be my guess, meaning that it's likely not holding enough vacuum to keep your petcock open.
Old Mar 12, 2011 | 07:24 AM
houseoutnumbered
Default fixed
I went through the carb cleaned and replaced seals.
the voes was replaced after waiting a week for it to come in at local HD store. (love these guys they always suggest I sell my bike and buy a new tc.)
Still had the idle problem, so after a few barley pops and thinking of that smart a@@ counter guy "you should get a newer bike".
Went through wiring and found the front cylinder plug wire to be bad and coroded socket on the coil.
After a couple more barley pops got it cleaned up and fixed the wire the bike runs pretty dam good.
Thanks everyone for your suggestions.
Old Mar 12, 2011 | 07:58 PM
the blob's Avatar
the blob
GLAD you found it!!
Old Mar 13, 2011 | 01:31 AM
1997bagger's Avatar
1997bagger
(love these guys they always suggest I sell my bike and buy a new tc.) so after a few barley pops and thinking of that smart a@@ counter guy "you should get a newer bike".
Found some good HD parts guys but many of them are just stroking keyboards to get enough experiance to get a job at Autozone alone trying to give advice
On the non-sarcastic note, glad you found the problem and didn't buy a bike off the showroom floor as suggested
Old Mar 13, 2011 | 11:46 AM
woodnbow's Avatar
woodnbow
Cool. And thanks for reporting back with the solution. Too many guys come on here, ask a question and then disappear without letting us know what that solution was, even if it did entail buying a new Twinkie... ;-)
