EVO cams
Old Oct 16, 2006 | 09:27 AM
dawg's Avatar
dawg
Default EVO cams
Like KeithB I am interested in some day getting an EVO along with my current scoot. Do these all have only one cam? If you do a cam change I assume you have to buy an EVO specific cam? The twins have chain or gear drive, what's the EVO setup?
Old Oct 16, 2006 | 09:39 AM
Hackd's Avatar
Hackd
Default RE: EVO cams
EVO's since 93 (I believe) have cams with zero overlap. EPA wielding their big sword. Andrews, S&S, Crane, etc....All make good cams for the EVO. I haven't checked lately but at one time there was a SE cam also available.
The cam sits behind the 'cam cone' and is gear driven. They come from the factory with an INA bearing, which you should definitely swap for a Torrington. A cam swap is a fairly easy procedure, if you've got the JIMS tool for removing/installing the inner cam bearing.
Old Oct 16, 2006 | 10:47 AM
HeavensDevil's Avatar
HeavensDevil
Checkout this link
http://motorcycleinfo.calsci.com/HP2.html
Old Oct 16, 2006 | 09:11 PM
Punky Brewster's Avatar
Punky Brewster
ORIGINAL: Hackd
I had a SE686 cam,& went with the Andrews EV3. More mid range power,what a difference
Old Oct 17, 2006 | 09:43 AM
Hackd's Avatar
Hackd
After some research it was the in 1992 that The MoCo started bending to the EPA on their cams. One of the options for EVO owners was to swap in a pre 92 EVO cam.
I have to say that the SE air cleaner + Cam + pipes + re-tuned CV carb = a HUGE difference in the way the bike ran. Truly felt like I was riding an 80" bike.
Old Oct 18, 2006 | 10:06 PM
iclick's Avatar
iclick
Shortly after buying this bike I installed an EV13 cam, HI-E4 ignition module, and Thunderslide kit (185 main, 42 low jets). Everything else is stock. Since then I haven't looked back, as this is a great setup. Low and midrange torque is excellent and power stays on 'til 6k rpm. Gas mileage averages around 54 mpg on my last few trips, mostly backroads with speeds at 65 mph ot less. It's an excellent setup for heavy bikes, but if I had a Dyna or Softail I'd install an EV27 instead.
Old Oct 19, 2006 | 02:05 AM
RudeDog's Avatar
RudeDog
Yes, EV-27 kicks a$$ on the Dynas and FXRs. I put one in my '91 FXRP and there was a considerable difference. The bike being a police bike originally, already had more power than a stock bike.
Old Oct 19, 2006 | 08:00 AM
Hackd's Avatar
Hackd
Here's a direct link to Andrews Cam: Click Here
I have been very satisfied with their product.
Old Oct 25, 2006 | 07:23 PM
HDWRENCH's Avatar
HDWRENCH
Looking at some CA cams they are in the - * of over lap, but yes EVO cams are for the single cam only set up. If you are stock take a look at cams that are going to wokr with compression ranges of 8.5-9.1 The andrews cams work well as do the cranes, comp cams. Huge selection of cams to fit every riding style and compression ratio.
Old Oct 26, 2006 | 02:38 AM
RudeDog's Avatar
RudeDog
I feel the need for a new post!
blair
Aug 15, 2010 10:45 AM
redrott
EVO
Jul 8, 2010 12:01 PM
L_Brown
Jun 23, 2010 10:31 AM
jdbluedevils39
Exhaust System Topics
Oct 1, 2009 02:16 PM
Beemervet
Dec 3, 2007 05:35 AM
