another 5 speed question
Old Apr 4, 2011 | 09:45 AM
jsbridgew's Avatar
jsbridgew
Default another 5 speed question
alright... i pulled the tranny shaft race, and took off the 32T pulley
it's a 91, and all that was on there was the allen screw, large hex nut, pulley, then spacer that sits inside the seal on top of the quad seal
.... seals are fine, no leaks
but just wanted to replace the pulley because teeth were all grimy and worn.... spacer was all rusted a bit and had some light surface grooves on it
....but everwhere i look all i find is the setup for what appears to be for the 92 and later, but with an 85D classification (#40210-85D) ....this includes everything above with the addition of a locking plate and an additional allen screw
can i go with this set, anyone know? ....it seems like an upgrade to the original setup
Old Apr 4, 2011 | 09:56 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Thats the upgrade for the drive sprocket. Around 125 bucks if I remember. Has a sprocket, spacer, seal, flat lock plate, & small cap screw.
I just replaced my sprocket and reused the original one screw lock. Was cheaper and less work.
Old Apr 4, 2011 | 10:37 AM
jsbridgew's Avatar
jsbridgew
that's what i figured, v-twin
was just reading that they upgraded it because those nuts are notorious for coming loose which moves the spacer away from the quad seal, causing a leak
whole kit is 195.00 from zanottis...yikes
jpcycles sells a BDL kit for about 125.00, but read where because they're so light they damage easily at around 30k
Old Apr 4, 2011 | 11:01 AM
V-Twins & Bowties
I've worked on bikes with the plate lock and they can work loose also. Just depends on how the rider rides.
Be aware that some of the replacement sprockets do not have both tapped holes for the small lock screw. They are in different locations. So if you just go the sprocket route check that it has both drilled and tapped holes.
Old Apr 4, 2011 | 11:03 AM
bagga's Avatar
bagga
look very closely at the main gear's splines where they match up with the pulley splines, if they are worn at all replace the main gear too. if there is any slop in the mating spline surface the pulley won't last long. the new pulley is 1/4 inch wider on it's splines so new spacer and seal is necessary.
Old Apr 4, 2011 | 11:15 AM
V-Twins & Bowties
Good point bagga. If the pulley/sprocket has the .415 offset old spacer can still be used.
Old Apr 4, 2011 | 11:16 AM
jsbridgew's Avatar
jsbridgew
even the one from HD, bagga?
i mean, if i gotta pull that main seal i will.... can't be too much to replacing that and the quad seal
any tips or suggestions?
paul
Old Apr 4, 2011 | 11:25 AM
V-Twins & Bowties
.415 offset no need for newer spacer. J P Cycles has them. Should be able to get at a Indy parts guy also.
Old Apr 4, 2011 | 11:28 AM
V-Twins & Bowties
Page 600 upper right hand J P Cycles 2011 catalog.
Old Apr 4, 2011 | 11:32 AM
jsbridgew's Avatar
jsbridgew
JP has the stock replacement with the .415 offset for like 45.00 and a new spacer from Jims.... stock spacer has some surface rust and some light surface grooves in it, so would be good to replace it i suppose
...much cheaper to go that route like you say, v-twin, if i don't have to do the whole upgrade considering the seals are fine
